Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 11.10.2012, 12:11   #1
Kent is offline
Kent
Ax 2009 AIF Web service
Hi,
In some cases inbound message can have field values which should convert to other values in Ax and assign to certain field.
For regular AIF services it is possible to create additional Ax<table>.parm<field> methods without real field behaind.
I tried to use the same for web services by using 'find' action, but system asks for real field. Is it possible to convert somehow incoming value to other value and assign to certain field?
An example, xml sends <field>1</field>, but in Ax it should be converted to 'Yes'.
Старый 11.10.2012, 21:38   #2
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
I think you need some transformation from one stuture to another
Here is some instructions
Axapta book for developer
Старый 11.10.2012, 22:03   #3
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1849 (69) ++++++++
Try any of these techniques (all standard AIF features)
- XSLT transformations
- AIF value lookups
- custom parm methods added to Axd document updating 'real' fields
-ТСЯ или -ТЬСЯ ?
Старый 12.10.2012, 10:49   #4
Kent is offline
Kent
- AIF value lookups
-Custom parm method doesn't work, I got error that field doesn't exist.
Старый 12.10.2012, 12:12   #5
Vadik is offline
Vadik
Аватар для Vadik
Сообщение от Kent Посмотреть сообщение
That works in 4.0. May I see the parm() metod, the schema and exact error message?
-ТСЯ или -ТЬСЯ ?
Часовой пояс GMT +3, время: 15:21.
