Старый 08.03.2024, 15:12   #1
25,497 / 847 (79) +++++++
crmtipoftheday: Tip #1449: Formula columns
Источник: https://crmtipoftheday.com/1449/form...ulated-columns
Formula columns are great, just read Work with Dataverse formula columns. But there are some limitations in the Power Fx functions you can use, as well as with the return types..
  • Need a formula column returning a whole number? Make it a decimal with 0 precision.
  • Need to produce currency? Make a formula to return a decimal, then convert it to currency using the good old calculated column where you can define the return data type instead of inferring.
  • Need a choice? Your choice can only be either yes or no. But the same trick applies. Do your magic in a formula column, then create a calculated column and go through the painful if-then-else process ad nauseam to cover all possible return values. To be honest, I’d rather eat a frog and write a plugin.
Personally, I think it’s all because, ironically, Power Fx in formula columns does not support Power function. Source: trust me, dude.
The post <a href="https://crmtipoftheday.com/1449/formula-columns-love-calculated-columns/">Tip #1449: Formula columns
crmtipoftheday: Tip #1448: Never delete columns in translation Blog bot Dynamics CRM: Blogs 0 07.03.2024 11:11
crmtipoftheday: Tip #1402: Why you should not use Microsoft Lists/SharePoint Lists for business-critical Power Apps Blog bot Dynamics CRM: Blogs 0 17.02.2021 15:12
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
Часовой пояс GMT +3, время: 16:12.
