Старый 20.05.2013, 18:11   #1
25,497 / 847 (79) +++++++
fatihdemirci: How to change grid row color in listpage form in Dynamics Ax 2012
Источник: http://www.fatihdemirci.net/index.ph...amics-ax-2012/
I need to change the grid row’s color in ax 2012 depend on the record status. The usual solution for this is to override the formdatasource method displayoption(). However, the form is listpage type and DataSource method can not be overiden. Customization works only in the interaction class for listpages. I try to do this [...]
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 12 Blog bot Dynamics CRM: Blogs 0 30.01.2013 01:11
emeadaxsupport: Final Microsoft Dynamics AX 2012 R2 Content Available! Blog bot DAX Blogs 0 04.12.2012 06:12
emeadaxsupport: How to disable the Public Sector solution when using Microsoft Dynamics AX 2012 Feature Pack Blog bot DAX Blogs 0 07.08.2012 00:13
emeadaxsupport: Dynamics AX 2012 Services: How to process big messages using File adapter Blog bot DAX Blogs 0 03.07.2012 00:12
axnontechnical: How to modify default cubes in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 07.03.2012 02:19
Часовой пояс GMT +3, время: 11:43.
