Старый 20.07.2010, 17:42   #1
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Post AxLINQ version 1.0
AxLINQ version 1.0
What is it ?
LINQ is short for Language INtegrated Query and was invented for the .net platform by the wizards at Microsoft.
AxLINQ is an attempt to bring a similar general purpose query language to the Microsoft Dynamics Ax platform (X++).
q = xFrom(n).in([1,5,4,3,8,10,7,9,2,6])
.Where(n <= 5)
.OrderBy(n)
.Select(n);
AxLINQ is a parser, that will grab the query as seen above and translate it into an expression tree, which is passed to a query provider.
The query provider interprets the expression tree an executes the query (Where, OrderBy and Select) on the given data source ([1,5,4,3,8,10,7,9,2,6]).
Currently the AxLINQ package include a query provider for enumerables of “anytype”, but the framework is prepared to be extended by any query provider that you can think of.
If you wan't to know about other projects I have, see my blog on http://sourcevault.blogspot.com
P.S. http://axlinq.codeplex.com/
Другие интересные материалы по Microsoft Dynamics AX , по Microsoft Dynamics CRM
За это сообщение автора поблагодарили: konopello (2).
Старый 20.07.2010, 21:13   #2
Андре is offline
Андре
Сотрудники компании GMCS
2,375 / 464 (20) +++++++
Чем то напомнило вот этот мой эксперимент.
Старый 21.07.2010, 10:53   #3
egorych is offline
egorych
Oracle
761 / 154 (7) ++++++
Я что-то не нашел - это для какой версии Ax ?
Старый 21.07.2010, 11:07   #4
Lucky13 is offline
Lucky13
714 / 198 (8) ++++++
Для Ax4/2009. См. Installation instructions.txt в архиве
В 3.0 не устанавливается, говорит формат файла не верный
enumerator, linq
emeadaxsupport: Error during Hotfix installation - "Version string portion was too short or too long" Blog bot DAX Blogs 0 13.11.2009 21:05
gl00mie: View AOCP/RPC Interface Version used by an Arbitrary DAX Binary Blog bot DAX Blogs 0 30.09.2008 16:05
axStart: Microsoft Dynamics AX 2009 White Paper: Team Foundation Server Version Control Setup Blog bot DAX Blogs 0 27.07.2008 13:06
axStart: Ax product version check Blog bot DAX Blogs 1 21.06.2008 23:38
Kashperuk Ivan: DEV_CreateNewProject tool version 2.0.0 Blog bot DAX Blogs 0 04.09.2007 01:12
Часовой пояс GMT +3, время: 00:48.
