Старый 17.01.2008, 15:40   #1
axaptafreak: Copying one line of a grid to Excel
Источник: http://axaptafreak.blogspot.com/2008...-to-excel.html
If you want to copy just one line from a Dynamics AX grid to Excel and you just click on the line marker of the grid to select the line, press Ctrl-C in Dynamics AX and then Ctrl-V in Excel, you will not get the line into Excel. Sometimes you will only have one active field of the line in Excel.
What you have to do: press SHIFT when you select the line. Then, copy and paste the line into Excel and it will work and copy the whole line. Helmut Wimmer
axaptapedia: Filter-by-Grid Blog bot DAX Blogs 2 30.05.2012 13:39
[Excel] - Несколько версий Excel на машине клиента Андре DAX: Программирование 11 07.08.2007 13:45
axaptafreak: Automatically open grid filter when opening form Blog bot DAX Blogs 2 20.06.2007 18:36
Вызов Item() для коллекций Excel Владимир Максимов DAX: Программирование 15 17.08.2006 19:47
Часовой пояс GMT +3, время: 18:12.
