Старый 01.12.2009, 21:05   #1
lcash: Project Time sheet entry
Источник: http://blogs.msdn.com/lcash/archive/...eet-entry.aspx
Just an FYI as I’ve had a few notes from a few different people about the timesheet entry on the Refresh 2 VM and the PSA Application Disk.
First you need to make sure you have the right period setups to get it to work then there is a random problem where the day fields don’t display on the EP to allow you to enter time correctly. You’ll be able to enter time in the AX form in the client.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash/
lcash: Using Project Time Sheets setting up the Period Code Blog bot DAX Blogs 0 31.07.2009 06:16
chrisfie: Project Server 2007 TechNet Webcasts recordings and decks Blog bot DAX Blogs 0 21.07.2009 10:05
AX UK: Project Time Management for Microsoft Dynamics AX 2009 - Beta Blog bot DAX Blogs 0 12.12.2008 12:05
Dynamics AX: Dynamics AX project success - Customer Ownership & Expectations Blog bot DAX Blogs 0 07.08.2007 21:10
Часовой пояс GMT +3, время: 14:43.
