Старый 31.07.2009, 06:16   #1
lcash: Using Project Time Sheets setting up the Period Code
Источник: http://blogs.msdn.com/lcash/archive/...riod-code.aspx
I had a prompt from Jose and Tim in the UK about reminding people about setting up the Period Code on an employee if you want to use Project Time sheets.
In the demo data only the user Prakash is setup. If you want to setup another user then the basic steps are :
1. Go to Human Resources\Common Forms\Employee Details. Locate the employee you need to setup. Click the Setup tab. Attach a PeriodCode.
2. Click the Setup Button. Select Period status.
3. Click the Update employee periods button. Enter a suitable period range. Click Ok.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash/
lcash: Setting up the Dynamics AX demo images in Hyper-V Blog bot DAX Blogs 0 29.07.2009 05:07
lcash: Setting up external networking on the Demo VMs Blog bot DAX Blogs 0 22.07.2009 09:05
lcash: Setting up Outlook Sync from Dynamics AX Blog bot DAX Blogs 0 21.07.2009 10:05
AX UK: Project Time Management for Microsoft Dynamics AX 2009 - Beta Blog bot DAX Blogs 0 12.12.2008 12:05
Часовой пояс GMT +3, время: 04:15.
