Старый 24.11.2012, 00:21   #1
Kent is offline
Kent
Query range
привет,
Query q = new Query();
QueryBuildDataSource qbds;
qbds = q.addDataSource(tablenum(Table1));
SysQuery::findOrCreateRange(qbds, fieldnum(Table1, Field1)).value(a);
SysQuery::findOrCreateRange(qbds, fieldnum(Table1, Field2)).value(b);
Both ranges for Field1 and Field2 works as AND expression.
Is it possible somehow handle those ranges as OR expression, between those fields?
Старый 24.11.2012, 07:54   #2
Player1 is offline
Player1
306 / 137 (5) +++++
http://www.axaptapedia.com/Expressions_in_query_ranges
queryBuildRange.value(strFmt('((%1 == %2) || (%3 == %4))',
    fieldStr(Table1, Field1),
    a,
    fieldStr(Table1, Field2),
    b));
За это сообщение автора поблагодарили: Kent (1).
Старый 24.11.2012, 14:21   #3
Kent is offline
Kent
Thanks
ax-erp: How to Set the Query Range on a SSRS Report Blog bot DAX Blogs 0 18.10.2012 19:11
Dates In An Extended Query Range Blog bot DAX Blogs 4 15.12.2011 10:50
sumitax: AX Queries – Passing query range as parameter Blog bot DAX Blogs 0 29.06.2011 13:11
sumitsaxfactor: Using Methods Inside Query Range Blog bot DAX Blogs 0 05.05.2011 20:12
axaptafreak: Label for Query Range cannot be modified (still) Blog bot DAX Blogs 2 25.07.2007 10:09
Часовой пояс GMT +3, время: 16:42.
