Старый 29.06.2011, 13:11   #1
sumitax: AX Queries – Passing query range as parameter
Источник: http://sumitax.wordpress.com/2011/06...-as-parameter/
Following is code for paramterized query. ie. query range passed as set of container values:
static FreeText
FindEngineerByTradeArea(NoYes    _skillRestriction = NoYes::No,
MxmServTradeId   _tradeCriteria = ,
NoYes
_areaRestriction = NoYes::No,
MxmServAreaId     _areaCriteria = ,
MxmServProficiency     _tradeProficiency =
MxmServProficiency::Primary,
MxmServPreference      _areaPreference   =
MxmServPreference::Primary
MxmServEngineerTrade
localtrade;
MxmServEngineerArea
localArea;
MxmServEngineer
engineer;
Query
qrTrade,qrArea, qrEngineer;
QueryBuildDatasource
qbdsTrade,qbdsArea,qbdsEngineer;
Queryrun
qrnTrade,qrnArea,qrnEngineer;
QueryBuildRange
qbrTrade,qbrEngineer,qbrArea,qbrTradeProficiency,qbrAreaPreference;
container
conEngid;
int
i=1;
FreeText
EngList;
//Trades  — Get requested trade
from Trade
if (_skillRestriction == NoYes::Yes
&& _areaRestriction == NoYes::Yes && _tradeProficiency
&& _areaPreference )   // If both restriction  i.e.Trade
and Area
qrTrade = new
Query();
qbdsTrade =
qrTrade.addDataSource(tableNum(MxmServEngineerTrade));
qbrTrade   =
qbdsTrade.addRange(fieldNum(MxmServEngineerTrade,TradeId));
qbrTrade.value(queryValue(_tradeCriteria));
//Adding
Preference for Proficiency
qbrTradeProficiency =
qbdsTrade.addRange(fieldNum(MxmServEngineerTrade,Proficiency));
qbrTradeProficiency.value(queryValue(_tradeProficiency));
qrnTrade = new
QueryRun(qrTrade);
while(qrnTrade.next())
localtrade = qrnTrade.get(tablenum(MxmServEngineerTrade));
if(localTrade.EngId)
if(!confind(conEngId,localTrade.EngId))
conEngid = conins(conEngid,conlen(conEngId)+1,localTrade.EngId);
for (i=1;
i<=conlen(conEngId); i++)
EngList +=  conpeek(conEngid,i)+ ,;
EngList =
substr(EngList,1,strlen(EngList)-1);
conEngId =
conNull();
qrArea = new
Query();
qbdsArea =
qrArea.addDataSource(tableNum(MxmServEngineerArea));
if(EngList)
qbrEngineer = qbdsArea.addRange(fieldNum(MxmServEngineerArea,EngId));
qbrEngineer.value(EngList);
if(_areaCriteria)
qbrArea = qbdsArea.addRange(fieldNum(MxmServEngineerArea,AreaId));
qbrArea.value(_areaCriteria);
//Adding preference for Area
if(_areaPreference)
qbrAreaPreference = qbdsArea.addRange(fieldNum(MxmServEngineerArea,Preference));
qbrAreaPreference.value(queryValue(_areaPreference));
qrnArea = new QueryRun(qrArea);
while(qrnArea.next())
localArea = qrnArea.get(tableNum(MxmServEngineerArea));
conEngId    =
conins(conEngId,conlen(conEngId)+1,localArea.EngId);
else
conEngId = conNull();
else if(_skillRestriction == NoYes::Yes
&& _areaRestriction == NoYes::No &&
_areaPreference)   // If Only Trade restriction
qrTrade = new
Query();
qbdsTrade =
qbrTrade=
qbdsTrade.addRange(fieldnum(MxmServEngineerTrade,TradeId));
//Adding
qrnTrade = new
QueryRun(qrTrade);
localTrade = qrnTrade.get(tablenum(MxmServEngineerTrade));
conEngId = conins(conEngId,conlen(conEngId)+1,localTrade.EngId);
else if(_skillRestriction == NoYes::No
&& _areaRestriction == NoYes::Yes)   // If Only area
restrction
qrArea = new
Query();
qbdsArea =
qbrArea =
qbdsArea.addRange(fieldNUm(MxmServEngineerArea,AreaId));
Area
if(_areaPreference)
qrnArea = new
QueryRun(qrArea);
localArea = qrnArea.get(tablenum(MxmServEngineerArea));
conEngId = conins(conEngId,conlen(conEngId)+1,localArea.EngId);
NoYes::No)         // If NO restriction
qrEngineer = new
Query();
qbdsEngineer =
qrEngineer.addDataSource(tableNum(MxmServEngineer));
qrnEngineer = new
QueryRun(qrEngineer);
while(qrnEngineer.next())
engineer = qrnEngineer.get(tablenum(MxmServEngineer));
conEngId = conins(conEngId,conlen(conEngId)+1,engineer.EngineerId);
EngList = ;
if(conEngId)
for(i=1;i<=conlen(ConEngId);i++)
EngList = substr(EngList,1,strlen(EngList)-1);
return EngList;
Последний раз редактировалось Poleax; 29.06.2011 в 13:26. Причина: оформление
msdax: How to Specify Range Values on a Query in a AX SSRS Report - AX Support - Site Home - MSDN Blogs Blog bot DAX Blogs 0 31.03.2011 11:11
jinx: Dynamics AX &ndash; Query-Ranges und Filtereinstellungen des Benutzers Blog bot DAX auf Deutsch 0 04.02.2010 00:05
axaptafreak: Label for query range cannot be modified in AX 5.0 Blog bot DAX Blogs 0 30.08.2007 16:50
Часовой пояс GMT +3, время: 09:16.
