Старый 12.03.2014, 14:11   #1
atinkerersnotebook: Use Filter By Selection To Quickly Find Common Records
Источник: http://atinkerersnotebook.com/2014/0...ommon-records/
Originally posted on Dynamics AX Tip Of The Day:
Filtering your list pages is even easier if you have an example of a record already on the page that matches what you are searching for because you can use it as a template for your search and use the Filter By Selection feature to find all of the other records that match, saving you a few extra keystrokes. This feature will turn you into a data filtering Ninja.
View original 49 more words
atinkerersnotebook: Quickly Filter Your Data Through The Type To Filter Box Blog bot DAX Blogs 0 10.03.2014 14:11
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Часовой пояс GMT +3, время: 04:25.
