Старый 19.09.2016, 21:13   #1
emeadaxsupport: Speed up Master plan when you have large number of inactive items
Источник: https://blogs.msdn.microsoft.com/axs...nactive-items/
Did you ever wonder why Master planning takes so much time processing hundreds of thousands of items, while you only have demand for a fraction of these items? We recognized this with several customers which had around a million items. The majority of the items were simply required in their system to allow looking up... Read more
За это сообщение автора поблагодарили: gl00mie (3).
emeadaxsupport: “Maximum number of items that can be serialized or deserialized in an object graph is '65535'.” In Dynamics AX 2012 Blog bot DAX Blogs 0 30.04.2015 18:12
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 08:22.
