Старый 30.04.2015, 18:12   #1
25,644 / 848 (80) +++++++
emeadaxsupport: “Maximum number of items that can be serialized or deserialized in an object graph is '65535'.” In Dynamics AX 2012
Источник: http://blogs.msdn.com/b/axsupport/ar...s-ax-2012.aspx
If you receive an error message like:
And the Article:
https://technet.microsoft.com/en-us/.../gg862502.aspx
Is not fixing the issue for you. Please use the following steps:
PART 1
Ax32serv.exe.config need to be updated in your system to match the below as from the article above.
1) Update the ServiceBehavior MetadataServiceBehavior to increase the maxItemsInObjectGraph, by adding the dataContractSerializer object.
          Endpoints and select the MetadataServiceEndpoint.
19) Set the BehaviorConfiguration property for the endpoint to your MetadataEndpointBehavior (it should show up in the drop down to be selected)
20) File > Save  To save your configuration changes, then close the WCF configuration editor
21) Back in the AX client configuration utility click Apply to save the changes
22) Restart the SSRS service
23) Run the report and it should now work
Note
Manually changing the config on the SSRS server means if any services are reconfigured it will not automatically pick up those changes.  Any changes made server side (through Ax32Serv.exe or through Inbound Ports form) will have to be updated in the config manually on this machine, or they can click Refresh to get the latest config and then recreate the endpoint behavior.  Given Visual Studio doesn't pick this up either, it seems typical that an application will not inherit endpoint behaviors from a service.  Ideally you would just get your customizations to a point that the defaults do not need to be overridden.
Related to this Note and Part 2  please note that there is a possibility to configure a separate AXC file for SSRS BC use only.
Please see
https://technet.microsoft.com/EN-US/library/hh389774.aspx
Notice:
"Microsoft provides programming
examples for illustration only, without warranty expressed or implied,
including, but not limited to, the implied warranties of merchantability or
fitness for a particular purpose. This mail message assumes that you are
familiar with the programming language that is being demonstrated and the tools
that are used to create and debug procedures."
This is not an officially tested solution by
Microsoft and should be fully tested before implementation.
Writer: Uwe Zimmermann <a href="mailto:uwezim@microsoft.com"uwezim@microsoft.com/a>
emeadaxsupport: New and updated content is available for cumulative update 6 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 27.06.2013 19:11
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Часовой пояс GMT +3, время: 18:58.
