Старый 03.12.2007, 16:00   #1
axaptapedia: Label
Источник: http://www.axaptapedia.com/Label
Summary: Added more information (Tnx Vailan for correcting the initial post)
Labels is a important system for handling of localized strings in Dynamic AX. The label-strings are stored in an file with the extension ”.ALD”. You will have to make one file for each language you make. The complete filename will be a mix between “label file id”, “language id” and with a preceeding “AX”
'''Filename example''':
AXSYSEN-GB.ALD
When you as a developer use labels you should create a new label-file so your customization will be portable. And even if your customization is for one language only you should do a label because you can reuse terms within your customization.
'''Content example''': (from: AxSYSen-gb.ald "line 6")
@SYS12 Account/Group number
The number 12 is the index of the translation, so an translation of this term (in for example Swedish) would be located in "AxSYSSV.ald" and read like...
@SYS12 Konto-/gruppnummer
axStart: When is my Label file updated in AX? Blog bot DAX Blogs 8 28.01.2010 22:09
DynaMihamAX: Label import problem in Dynamics AX 4.0 Blog bot DAX Blogs 0 12.12.2008 13:05
axaptapedia: Label Blog bot DAX Blogs 0 30.11.2007 20:41
axaptapedia: Error messages Blog bot DAX Blogs 0 27.11.2007 13:30
Часовой пояс GMT +3, время: 13:01.
