Старый 27.11.2007, 13:30   #1
axaptapedia: Error messages
Источник: http://www.axaptapedia.com/Error_messages
Summary: Error messages when we want to export table into Excel file
Lets say, we have this error messages when we want to export table into Excel file:
Error executing code: DictEnum object not initialized.
Stack trace:
\Classes\DictEnum\label
\Classes\SysExcelTemplateWizard\formatCell - line 24
\Classes\SysExcelTemplateWizard\formatType - line 21
\Classes\SysExcelTemplateWizard\formatColumns - line 37
\Classes\SysExcelTemplateWizard\createTemplate - line 17
\Classes\SysExcelTemplateWizard\run - line 21
\Classes\SysExcelTemplateWizard\main - line 11
The solution is :
1. Debug class named SysExcelTemplateWizard
In method formatCell - line 24, error started:
label = new DictEnum(_tmpExcelField.methodEnumId).label();
It seem 'label' variable not filled with proper value.
2. Check field of the table that use Enums.
3. Check that Enums, make sure Enum label filled with proper value.
4. Synchronize database.
5. Reexport table into Excel file.
Hope its works....
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 19:39.
