Старый 01.12.2009, 21:05   #1
25,644 / 848 (80) +++++++
lcash: Arabic Region
Источник: http://blogs.msdn.com/lcash/archive/...ic-region.aspx
I had a note from a Khurram that brought this to my attention. In the Hotfix Rollup 2 package it included localization updates for the Arabic Region. We included this on the Refresh 2 demo VM.
You can see this in the config keys in the demo VM
Now because we have functionality in the higher layers in the demo VM like Project time, payroll, environment dashboard etc you may not see the right tabs show in GL Journals, Project Journals etc. You can merge that functionality into a higher layer.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash/
lcash: Processing OLAP Cubes and AX Companies Blog bot DAX Blogs 0 15.10.2009 07:06
lcash: Using Project Time Sheets setting up the Period Code Blog bot DAX Blogs 0 31.07.2009 06:16
lcash: ProjPost Class compile error Blog bot DAX Blogs 0 24.07.2009 04:20
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 19:45.
