Старый 26.03.2014, 01:17   #1
25,644 / 848 (80) +++++++
atinkerersnotebook: Setting Forms to Automatically Open In Edit Mode
Источник: http://atinkerersnotebook.com/2014/0...-in-edit-mode/
Originally posted on Dynamics AX Tip Of The Day:
There are those people that are casual users of Dynamics AX that look through the data and occasionally update it, and there are those that are always updating and tweaking the data in the system. If you are in the latter of the two groups, then you probably hate going into a form and having to click on the Edit button so that you can change the data. It may be one click, but if you are doing it thousands of times a day, then this quickly starts becoming a chore. Luckily there is a simple option that you can change that will make it so that every time you go into a form, it will automatically start in edit mode.With all the spare time that you just got, what on earth will you do with yourself.
View original 85 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Часовой пояс GMT +3, время: 23:10.
