Старый 29.04.2014, 15:11   #1
atinkerersnotebook: Set Up Mandatory Field Checks For Products
Источник: http://atinkerersnotebook.com/2014/0...-for-products/
Originally posted on Dynamics AX Tip Of The Day:
Dynamics AX runs on data, and the cleaner the data, the less sludge you have in the system, slowing it down. A field that is not set up correctly won’t kill the system (usually) but it will probably cause a little extra work down the line. Fortunately Mandatory Fields Checks feature allows you to run a quick check on the data to make sure that every t is crossed and i is dotted. All you need to do is set it up.It’s like having a multi-point inspection on your car without the hefty mechanics bill.
View original 216 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Часовой пояс GMT +3, время: 15:02.
