Старый 10.12.2015, 09:12   #1
mfp: X++ in AX7: Client/Server keywords
Источник: http://blogs.msdn.com/b/mfp/archive/...-keywords.aspx
In AX7 all X++ code is running on the server tier. No exceptions. The compiler is ignoring client and server keywords.
When you come across any of these just delete them without a second thought:
  • Client and Server keywords
  • //AOSRunMode::xxx
  • xGlobal::ClientKind()
  • Dangling semicolons (but that is another story)
Similarly, if you stumble into any code that was taking the journey to the opposite tier to do some "magic" and then pack down the results in a container – consider refactoring the code. The journey is not happening anymore, and it is pure overhead. Typically such methods are static methods named xxx_OnServer() or xxxClient().
THIS POST APPLIES TO MICROSOFT DYNAMICS AX7 PREVIEW; IS PROVIDED AS-IS AND CONFERS NO RIGHTS.
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
mfp: Garbage Collection and RPC calls in X++ Blog bot DAX Blogs 0 03.10.2014 00:13
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Часовой пояс GMT +3, время: 16:43.
