Старый 10.08.2017, 20:11   #1
organicax: External catalog setup using cXML in D365 – Part 1
Источник: https://organicax.com/2017/08/10/ext...n-d365-part-1/
In  previous post we had a look at the user experience for the requisition punchOut which uses the new cXML capabilities for the external catalog. In this post let’s have a look at the external catalog setup.
There are only a few parameters that you will need to fill in which is the vendor, category and the message format. The message format is really the key here and that is where you will need to do pre-work with your supplier as they will need to give you the “login” information to populate the cXML setup message. In this video I’m using a pre-configured message and we’ll go over the details of that message format in a follow-up post.
Here is a quick overview.
D365 July 2017 Update 8 (7.0.4565.16211)
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: Purchase requisition PunchOut – External catalog. Blog bot DAX Blogs 0 25.07.2017 12:11
organicax: cXML punchOut protocol handler for AX2012 Blog bot DAX Blogs 0 27.09.2016 14:11
DynamicsAxSCM: Import vendor catalogs: from setup to importing a sample catalog – Part 2 (Importing a sample catalog) Blog bot DAX Blogs 0 09.09.2012 20:15
DynamicsAxSCM: Import vendor catalogs: from setup to importing a sample catalog – Part 1 (Setup) Blog bot DAX Blogs 0 30.08.2012 02:14
Часовой пояс GMT +3, время: 19:50.
