Старый 27.09.2016, 14:11   #1
organicax: cXML punchOut protocol handler for AX2012
Источник: https://organicax.com/2016/09/27/cxm...er-for-ax2012/
I’ve done a lot of posts about the OCI punchOut protocol. Probably the more common implementation you will see with customers and suppliers wanting to automate employee procurement experience is with the cXML protocol. In the USA most of the large office supply, hardware supply, computers suppliers have cXML enabled with their supplier shopping sites.
cXML or commerce eXtensible Markup Language is a protocol developed by Ariba in 1999 you can read more about it at http://cxml.org
In AX2012 there is a framework for punchOut but it doesn’t include code to handle the cXML messages. I’m providing a copy of a protocol handler as sample code that you can use as a framework for your own implementations. You can download this from http://ax2012r3cxml.codeplex.com
For setup notes please see this post
cXML punchout protocol handler installation for AX2012 R3
For setup of the external catalog once you have imported the code see this post
External catalog setup using the cXML protocol handler for PunchOut
For an overview of the user flow using cXML see this post
cXML punchOut user flow
The cXML protocol handler supports a specific set of message for the punchOut see this post
PunchOutOrderMessageHeader – operationsAllowed
For working with commodity codes from the cXML messages see this post
cXML punchOut commodity code handling
For using the message log feature for troubleshooting see this post
cXML punchOut message logging
For notes on unit of measure handling with cXML see this post
cXML PunchOut unit of measure handling
For notes on currency handling with cXML see this post
cXML PunchOut – currency handling
For additional information about cXML as described in the cXML user codes see this post
cXML User Guides
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: WMS Mobile Device indirect menu items – compile of posts. Blog bot DAX Blogs 0 03.09.2016 01:24
organicax: WMS Packing compile of setup posts. Blog bot DAX Blogs 0 26.07.2016 16:11
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
Kine: DynamicsNAV protocol handler Blog bot Dynamics CRM: Blogs 0 18.05.2012 09:14
Kine: DynamicsNAV protocol handler Blog bot Dynamics CRM: Blogs 0 18.05.2012 04:14
Часовой пояс GMT +3, время: 15:34.
