Старый 13.09.2017, 13:11   #1
axinthefield: New for Premier customers – Material Requirements Planning (MRP) Assessment for Dynamics AX 2012 R3
Источник: https://blogs.msdn.microsoft.com/axi...cs-ax-2012-r3/
Get the most out of the Master Planning module by ensuring you have accurate and consistent data, the configuration settings you need, and the most important application updates. Identify MRP specific hotfixes required for Master Planning health. Identify possible MRP specific data problems that impact Master Planning performance and/or results. Identify and evaluate key MRP...
Старый 13.09.2017, 15:54   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
О как. что-то новое получается, т.е. на первый взгляд MS то должен выложить все эти проверки и советы для всех, а не предлагать их для крупных клиентов(за немалые деньги как я понимаю)
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
emeadaxsupport: Form created in e.g. AX 2012 RTM or AX 2012 R2 with ManagedHost control on its design fails to open on AX 2012 R3 Blog bot DAX Blogs 0 21.09.2015 19:11
DAX: Calling all developers: how to ease the learning curve of Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 27.08.2014 22:11
emeadaxsupport: Get started with AX 2012 R3! Blog bot DAX Blogs 0 05.05.2014 09:11
Часовой пояс GMT +3, время: 03:45.
