Старый 21.09.2015, 19:11   #1
emeadaxsupport: Form created in e.g. AX 2012 RTM or AX 2012 R2 with ManagedHost control on its design fails to open on AX 2012 R3
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r3.aspx
Applies to AX 2012 R2 & AX 2012 R3
Consider the following scenario:
When a form is created in e.g. AX 2012 RTM or AX 2012 R2 and a ManagedHost control is added on its design,
like "Microsoft.Dynamics.AX.Framework.Client.Controls.ChartToolBar".
Then when the form is deployed on a newer AX version, e.g. AX 2012 R3 environment,
the form no longer opens but throws the following exception:
Could not load file or assembly 'Microsoft.Dynamics.AX.Framework.Client.Controls, Version=6.2.0.0,
Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
The located assembly's manifest definition does not match the assembly reference.
(Exception from HRESULT: 0x80131040)
To resolve the above addressed issue, please do as follows:
Adding new assembly bindings into Ax32.exe.config to redirect 6.0.0.0 and 6.2.0.0 references to 6.3.0.0 assembly.
Here is what precisely you need to do:
-Shutdown your AX client
-Find the “Ax32.exe.config” file under your Client\Bin directory, normally under
“C:\Program Files (x86)\Microsoft Dynamics AX\60\Client\Bin”
-Edit the file in Notepad and add the following assembly binding (Highlighted in yellow).
-Save the file, but please make sure to keep it in the original format
-Start AX client and try your scenario
The Ax32.exe.config file content will look like the following after the changes:
emeadaxsupport: Sending email notifications for Retail orders [AX 2012 R2 and R3] Blog bot DAX Blogs 0 17.03.2015 00:11
emeadaxsupport: AX 2012 R2-R3 - Creating a new Retail product and syncing this to an existing Online Store Blog bot DAX Blogs 0 13.11.2014 05:27
Axilicious:Hosting custom WPF calendar control in AX 2012 Blog bot DAX Blogs 0 20.05.2013 18:11
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
Часовой пояс GMT +3, время: 07:51.
