Старый 30.08.2018, 20:12   #1
25,644 / 848 (80) +++++++
d365technext: Import Export Model D365FO
Источник: http://d365technext.blogspot.com/201...el-d365fo.html
Export Model
ModelUtil.exe -export -metadatastorepath=[path of the metadata store] -modelname=[name of the model to export] -outputpath=[path of the folder where the model file should be saved]
ModelUtil.exe -export -metadatastorepath=C:\AOSService\PackagesLocalDirectory -modelname="FleetManagement" -outputpath=c:\temp
Import Model
ModelUtil.exe -import -metadatastorepath=[path of the metadata store where model should be imported] -file=[full path of the file to import]
ModelUtil.exe -import -metadatastorepath=C:\AOSService\PackagesLocalDirectory -modelname="FleetManagement" -outputpath=c:\temp
Important
You can find the model name in Descriptor file in the tag of Tag
alexef: Sample Extension v2.0 — Dynamics NAV / AL extension / SaaS — ALF Export Setup Tabs to Excel Blog bot NAV: Blogs 3 05.10.2018 23:13
d365technext: Export & Import Project D365FO Blog bot DAX Blogs 0 16.08.2018 14:11
a33ik: How to import project from one model to another (D365FO) Blog bot DAX Blogs 0 26.12.2017 19:11
emeadaxsupport: Unable to import model files generated using Export-AxModel cmdlet, or upload it to LCS for Customization analysis Blog bot DAX Blogs 0 05.12.2014 19:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Часовой пояс GMT +3, время: 04:57.
