Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 07.07.2011, 16:05   #1
Dark Smile is offline
Dark Smile
Junior AX Developer
16 / 10 (1) +
Get the parent Table of a field only by fieldid
Hey Guys,
I got the following informations:
- UtilElementName (Name of a tablefield)
- UtilElementType (=TableField)
- ID ( fieldname2id(UtilElementName) )
What i want is the Table which the field is in.
I tried to use TreeNode but i failed because the path isn't complete (\\Data Dictionary\\Tables\\???\\Fieldname).
I also can't use SysDictField because it wants a TableId too.
My next idea was to search for the Table but i don't get it with SysTreeSearch - maybe i haven't the needed expierince.
So can anyone help me to get the parentTable ?
Thank you.
Kind Regards
Robin
Старый 07.07.2011, 16:16   #2
S.Kuskov is offline
S.Kuskov
3,440 / 1776 (66) ++++++++
UtilElements
UtilIdElements.parentId?
Последний раз редактировалось S.Kuskov; 07.07.2011 в 17:07.
Старый 07.07.2011, 16:21   #3
Dark Smile
Junior AX Developer
16 / 10 (1) +
i don't have the utilElements.
These are Parameters given in Class SysCompilerOutput\compilerStatus...
protected void compilerStatus(UtilElementType _utilElementType, str _utilElementName)
Kind Regards
Robin
Старый 07.07.2011, 17:06   #4
S.Kuskov is offline
S.Kuskov
while select UtilIdElements
where
    UtilIdElements.recordType == _UtilElementType &&
    UtilIdElements.name == _UtilElementName
За это сообщение автора поблагодарили: Billings81 (0).
Старый 07.07.2011, 19:28   #5
Dark Smile
Junior AX Developer
16 / 10 (1) +
okay, its simple... thank you
Kind Regards
Robin
axaptapedia: Table Field Group Blog bot DAX Blogs 0 02.07.2011 05:37
axaptapedia: Table Field Group Blog bot DAX Blogs 0 25.06.2011 06:33
Халтура в AX2009: идентификаторы из USR в GLS, GLP и даже SYS-слоях EVGL DAX: Программирование 2 21.02.2011 19:44
DynamicsAxSCM: The InventTrans table. Explore various field usages. Blog bot DAX Blogs 0 09.11.2010 19:10
gatesasbait: FieldId switch-case on an table's array-type field Blog bot DAX Blogs 0 20.12.2007 20:30
Часовой пояс GMT +3, время: 01:38.
