Старый 02.07.2011, 05:37   #1
axaptapedia: Table Field Group
Источник: http://axaptapedia.com/Table_Field_Group
Summary:
=== Description ===
The following demonstrates how to add field group fields with code.
[[Image:FieldGroup.png|Before]]
=== Dynamics AX versions ===
Has been tested on [[Build_numbers|Dynamics AX 2009 SP1 RU-6]]
=== Code ===
#AOT
#define.FieldGroups('Field Groups')
#define.TableFieldGroupItem('PROPERTIES\nTable\n#\%1\nDataField\n#\%2\nENDPROPERTIES')
TreeNode table, fieldGroups, fieldGroup, field;
// Gets the Address table.
table = TreeNode::findNode(#TablesPath + #AOTDelimiter + tableStr(Address));
// Gets the Address table's Field Groups node.
fieldGroups = table.AOTfindChild(#FieldGroups);
// Gets the 'Delivery' field group.
fieldGroup = fieldGroups.AOTfindChild(tableFieldGroupStr(Address, Delivery));
// Adds the field 'Name' to the 'Delivery' field group.
fieldGroup.AOTadd(fieldStr(Address, Name));
// Adds the display method 'tableRelationName' to the 'Delivery field group.
// This uses the Address table's RecVersion field as a dummy and converts it
// to a display field by setting its properties.
field = fieldGroup.AOTadd(fieldStr(Address, RecVersion));
field.AOTSetProperties(strFmt(
    #TableFieldGroupItem,
    tableStr(Address),
    tablemethodstr(Address, tableRelationName)));
// Saves the changes to the table.
table.AOTsave()
Последний раз редактировалось Poleax; 04.07.2011 в 10:49. Причина: оформление
axaptapedia: Table Field Group Blog bot DAX Blogs 0 25.06.2011 06:33
Халтура в AX2009: идентификаторы из USR в GLS, GLP и даже SYS-слоях EVGL DAX: Программирование 2 21.02.2011 19:44
DynamicsAxSCM: The InventTrans table. Explore various field usages. Blog bot DAX Blogs 0 09.11.2010 19:10
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
Часовой пояс GMT +3, время: 06:59.
