Старый 12.07.2006, 18:35   #2
slava09 is offline
slava09
Аватар для slava09
Дети Юза
1,642 / 237 (11) ++++++
Вот такую ошибку выдает при создании конфигурации:
Программе не удалось установить хранимые процедуры интеграции.
Описание процедуры:
*    Exec only in Axapta for SKU Levels.
CREATE proc dbo.DP_LOW_LEVELS
as
declare @
erpCompany char(3)
SET @erpCompany ''
SELECT @erpCompany CON_ERP_COMPANY
from
MBS_CONFIGURATION
declare @skuUse char(1)
SET @skuUse 'F'
select @skuUse SKU_USE
from
MBS_SKU_HIERARCHY
if( @skuUse 'F' )
begin
DELETE FROM
[SLAVA].[AXDB].[dbo].[MBS_SKU_MAPPINGS]
INSERT INTO [SLAVA].[AXDB].[dbo].[MBS_SKU_MAPPINGS]
DP_SKU], [ITEM_ID], [START_ITEM_ID], [COLOR_ID], [SIZE_ID], [CONFIG_ID], [CAT_CODE], [DATA_AREA_ID])
SELECT DISTINCT B_ENTITY_IDENB_ENTITY_IDENB_ENTITY_IDEN''''''CAT_CODE, @erpCompany
FROM BASE_ENTITIES
MBS_ITEM_DIMENSION_VIEW
WHERE B_ENTITY_IDEN
ITW_ITEM_ID
return
end
declare @SKU_IDEN varchar (80)
declare @
ITEM_IDEN varchar (80)
declare @
T_ITEM_IDEN varchar (80)
declare @
ITEM_CODE int
declare @MAX_ENTITY_CODE int
declare @V_COLOR nvarchar(40)
declare @
V_SIZE nvarchar(40)
declare @
V_CONF nvarchar(40)
exec DP_MBS_LANG 'Color', @V_COLOR output
exec DP_MBS_LANG
'Size', @V_SIZE output
exec DP_MBS_LANG
'Conf', @V_CONF output
declare @V_SKU_UPPER nvarchar(40)
declare @
V_SKU_MEDIUM nvarchar(40)
declare @
V_SKU_LOWER nvarchar(40)
SET @V_SKU_UPPER=''
SET @V_SKU_MEDIUM=''
SET @V_SKU_LOWER=''
declare @V_SKU_CAT nvarchar(40)
declare @
LEVEL_SKU_CAT int
declare @PLANNER varchar)
DELETE FROM MBS_SKU_DIMENSIONS
delete from
[SLAVA].[AXDB].[dbo].MBS_SKU_MAPPINGS;
DELETE FROM CATEGORIES_HRCY WHERE CAT_F_CODE>=9000 or CAT_S_CODE>=9000
DELETE FROM APPLICATIONS_CATEGORIES WHERE CAT_CODE
>=9000
DELETE FROM CATEGORIES_POSITIONS WHERE CAT_CODE
>=9000
DELETE FROM INDICATORS_CATEGORIES WHERE
CAT_BE_CODE
>=9000 OR CAT_MK_CODE>=9000
OR CAT_BK_CODE>=9000 OR CAT_ME_CODE>=9000
DELETE FROM CATEGORIES WHERE CAT_CODE
>=9000
declare @lang_Item_value nvarchar80 )
declare @
item_cat_code int
exec DP_MBS_LANG
'Item', @lang_Item_value output
declare @existsCOLORID INT
declare @existsSIZEID INT
declare @existsCONFIGID INT
declare @numSkuLevels INT
SET
@existsCOLORID 0
IF EXISTSSELECT 1 FROM [SLAVA].[AXDB].[dbo].SYSCOLUMNS
WHERE ID
= ( SELECT ID FROM [SLAVA].[AXDB].[dbo].SYSOBJECTS
WHERE NAME
'INVENTDIMCOMBINATION' AND XTYPE 'U')
AND
NAME 'INVENTCOLORID' )
SET @existsCOLORID 1
SET
@existsSIZEID 0
WHERE ID
WHERE NAME
AND
NAME 'INVENTSIZEID' )
SET @existsSIZEID 1
SET
@existsCONFIGID 0
WHERE ID
WHERE NAME
AND
NAME 'CONFIGID' )
SET @existsCONFIGID 1
SET
@numSkuLevels = @existsCOLORID + @existsSIZEID + @existsCONFIGID
SELECT
@V_SKU_UPPER=
case
when [SKU_UPPER] = 'C' then @V_COLOR
when
[SKU_UPPER] = 'S' then @V_SIZE
when
[SKU_UPPER] = 'F' then @V_CONF
end
FROM
[MBS_SKU_HIERARCHY]
if
not (@V_SKU_UPPER is null)
begin
INSERT INTO
[MBS_SKU_DIMENSIONS]([SKU_ORDER], [SKU_DIM_NAME])
VALUES(1, @V_SKU_UPPER)
end
SELECT
@V_SKU_MEDIUM=
case
when [SKU_MEDIUM] = 'C' then @V_COLOR
when
[SKU_MEDIUM] = 'S' then @V_SIZE
when
[SKU_MEDIUM] = 'F' then @V_CONF
end
FROM
[MBS_SKU_HIERARCHY]
if
not (@V_SKU_MEDIUM is null)
begin
INSERT INTO
VALUES(2, @V_SKU_MEDIUM)
end
SELECT
@V_SKU_LOWER=
case
when [SKU_LOWER] = 'C' then @V_COLOR
when
[SKU_LOWER] = 'S' then @V_SIZE
when
[SKU_LOWER] = 'F' then @V_CONF
end
FROM
[MBS_SKU_HIERARCHY]
if
not (@V_SKU_LOWER is null)
begin
INSERT INTO
VALUES(3, @V_SKU_LOWER)
end
declare SKU_CATEGORIES cursor for
select
L
.SKU_DIM_NAME
from
MBS_SKU_DIMENSIONS L
where
L
.SKU_DIM_NAME=@V_SKU_UPPER
UNION
select
L
.SKU_DIM_NAME+'_'+M.SKU_DIM_NAME
from
,MBS_SKU_DIMENSIONS M
WHERE
L
.SKU_DIM_NAME<>M.SKU_DIM_NAME
AND L.SKU_DIM_NAME=@V_SKU_UPPER AND M.SKU_DIM_NAME=@V_SKU_MEDIUM
UNION
select
L
.SKU_DIM_NAME+'_'+M.SKU_DIM_NAME+'_'+U.SKU_DIM_NAME
from
,MBS_SKU_DIMENSIONS M,MBS_SKU_DIMENSIONS U
WHERE
L
AND M.SKU_DIM_NAME<>U.SKU_DIM_NAME
AND L.SKU_DIM_NAME=@V_SKU_UPPER AND M.SKU_DIM_NAME=@V_SKU_MEDIUM AND U.SKU_DIM_NAME=@V_SKU_LOWER
open SKU_CATEGORIES
fetch next from SKU_CATEGORIES into
@V_SKU_CAT
SET
@LEVEL_SKU_CAT=0
while (@@FETCH_STATUS=0)
begin
if @LEVEL_SKU_CAT=AND @V_SKU_LOWER<>'' AND @numSkuLevels 3
begin
INSERT INTO CATEGORIES
(CAT_CODECAT_IDENCAT_DESC,CAT_SEVERITY,HRCY_FLAG,FLAG)
VALUES(9002,@V_SKU_CAT,@V_SKU_CAT,0,0,0)
INSERT INTO [CATEGORIES_HRCY]([CAT_F_CODE], [CAT_S_CODE])
VALUES(90019002)
PRINT @
V_SKU_LOWER
DECLARE @lowerLevelSQLString NVARCHAR(4000)
SET @lowerLevelSQLString dbo.GET_LOWER_SKU_LEVEL_SQL_STRING( @existsCOLORID, @existsSIZEID, @existsCONFIGID,
erpCompany, @V_SKU_UPPER, @V_SKU_MEDIUM, @V_SKU_LOWER, @V_COLOR, @V_SIZE, @V_CONF, @lang_Item_value )
EXEC sp_executesql @lowerLevelSQLString
declare @ITEM_DESC char(255)
declare
SKU_C_ENTITY_LOWER cursor for
SELECT
DP_SKU
,START_ITEM_ID,ITEM_ID
FROM
WHERE CAT_CODE
=9002
UNION
SELECT DISTINCT
ITW_ITEM_ID
+'_UNDEF_UNDEF_UNDEF' AS NEWSKU,ITW_ITEM_ID+'_UNDEF_UNDEF',ITW_ITEM_ID
FROM
MBS_ITEM_DIMENSION_VIEW IV
WHERE IV
.ITW_ITEM_ID NOT IN
SELECT DISTINCT ITW_ITEM_ID
FROM
MBS_ITEM_DIMENSION_VIEW V
SLAVA].[AXDB].[dbo].INVENTDIMCOMBINATION idc
WHERE
V
.ITW_ITEM_ID=ITEMID
AND
ITW_ATT_VALUE IN select ITM_DP_IDEN from MBS_ITEMS )
open SKU_C_ENTITY_LOWER
fetch next from SKU_C_ENTITY_LOWER into
@SKU_IDEN,@T_ITEM_IDEN,@ITEM_IDEN
while( @@FETCH_STATUS )
begin
SET
@ITEM_DESC=''
SELECT
@ITEM_DESC=IDW_ATT_VALUE
FROM
MBS_ITEM_DESC_VIEW
WHERE IDW_ITEM_ID
=@ITEM_IDEN
SET
@ITEM_CODE=-1
SELECT
@ITEM_CODE=B_ENTITY_CODE
FROM BASE_ENTITIES
WHERE B_ENTITY_IDEN
=@T_ITEM_IDEN
exec DP_ASSOCIATE_ITEMS_GET_PLANNER
@ITEM_IDEN, @PLANNER output
if (@ITEM_CODE=-1)
begin
SELECT
@MAX_ENTITY_CODE isnullmaxB_ENTITY_CODE ) + 1)
FROM
BASE_ENTITIES
INSERT INTO
BASE_ENTITIES
( [B_ENTITY_CODE], [B_ENTITY_IDEN], [B_ENTITY_CLASS], [B_ENTITY_DESC], [CAT_CODE], [PLANNER] )
VALUES        ( @MAX_ENTITY_CODE, @T_ITEM_IDEN'-', @ITEM_DESC9002, @PLANNER )
SET @ITEM_CODE=@MAX_ENTITY_CODE
end
if (@ITEM_CODE<>-1)
begin
SELECT
FROM
BASE_ENTITIES
INSERT INTO
BASE_ENTITIES
VALUES        ( @MAX_ENTITY_CODE, @SKU_IDEN'-', @ITEM_DESC9002, @PLANNER )
INSERT INTO B_ENTITIES_HRCY ([B_ENTITY_F_CODE], [B_ENTITY_CODE])
VALUES            (@ITEM_CODE, @MAX_ENTITY_CODE)
end
end
close SKU_C_ENTITY_LOWER
deallocate SKU_C_ENTITY_LOWER
end
if @LEVEL_SKU_CAT=AND @V_SKU_MEDIUM<>'' AND @numSkuLevels >= 2
begin
VALUES(9001,@V_SKU_CAT,@V_SKU_CAT,0,0,0)
VALUES(9000,9001)
PRINT @
V_SKU_MEDIUM
DECLARE @mediumLevelSQLString NVARCHAR(4000)
SET @mediumLevelSQLString dbo.GET_MEDIUM_SKU_LEVEL_SQL_STRING( @existsCOLORID, @existsSIZEID, @existsCONFIGID,
erpCompany, @V_SKU_UPPER, @V_SKU_MEDIUM, @V_COLOR, @V_SIZE, @V_CONF )
EXEC sp_executesql @mediumLevelSQLString
insert into
(DP_SKU,START_ITEM_ID,ITEM_ID,CAT_CODE,COLOR_ID,SIZE_ID,CONFIG_ID,DATA_AREA_ID)
SELECT DISTINCT
S
.DP_SKU '_UNDEF' AS NEWSKUS.DP_SKUS.ITEM_ID9001'''''', @erpCompany
FROM
[SLAVA].[AXDB].[dbo].MBS_SKU_MAPPINGS S
WHERE
S
.CAT_CODE 9000
AND S.START_ITEM_ID IN
SELECT DISTINCT
START_ITEM_ID
FROM
WHERE
S
.CAT_CODE 9000
AND COLOR_ID ''
AND SIZE_ID ''
AND CONFIG_ID ''
AND
S.ITEM_ID NOT IN
SELECT DISTINCT
ITEM_ID
FROM
WHERE
S
.CAT_CODE 9001
declare @
SSQL NVARCHAR4000 );
SET @SSQL ' DELETE FROM [SLAVA].[AXDB].[dbo].[MBS_SKU_MAPPINGS]
WHERE CAT_CODE=9001
AND [PROG] NOT IN (
SELECT [PROG] FROM [SLAVA].[AXDB].[dbo].[MBS_SKU_MAPPINGS] S,[SLAVA].[AXDB].[dbo].[INVENTDIMCOMBINATION] idc
WHERE CAT_CODE=9001
AND idc.ITEMID=S.ITEM_ID '
if ((@V_SKU_UPPER=@V_CONF) or (@V_SKU_MEDIUM=@V_CONF) )
begin
SET
@SSQL= @SSQL ' AND idc.CONFIGID=S.CONFIG_ID '
end
if ((@V_SKU_UPPER=@V_SIZE) or (@V_SKU_MEDIUM=@V_SIZE) )
begin
SET
@SSQL= @SSQL ' AND idc.INVENTSIZEID=S.SIZE_ID '
end
if ((@V_SKU_UPPER=@V_COLOR) or (@V_SKU_MEDIUM=@V_COLOR) )
begin
SET
@SSQL= @SSQL ' AND idc.INVENTCOLORID=S.COLOR_ID '
end
SET
@SSQL= @SSQL ')'
declare SKU_C_ENTITY_MEDIUM cursor for
SELECT
DP_SKU
FROM
WHERE CAT_CODE
=9001
open SKU_C_ENTITY_MEDIUM
fetch next from SKU_C_ENTITY_MEDIUM into
begin
SET
@ITEM_DESC=''
SELECT
FROM
MBS_ITEM_DESC_VIEW
WHERE IDW_ITEM_ID
=@ITEM_IDEN
SET
@ITEM_CODE=-1
SELECT
FROM
BASE_ENTITIES
WHERE B_ENTITY_IDEN
=@T_ITEM_IDEN
if (@ITEM_CODE=-1)
begin
SELECT
FROM
BASE_ENTITIES
INSERT INTO
BASE_ENTITIES
VALUES        ( @MAX_ENTITY_CODE, @T_ITEM_IDEN'-', @ITEM_DESC9001, @PLANNER )
end
if (@ITEM_CODE<>-1)
begin
SELECT
FROM
BASE_ENTITIES
INSERT INTO
BASE_ENTITIES
VALUES        ( @MAX_ENTITY_CODE, @SKU_IDEN'-', @ITEM_DESC9001, @PLANNER )
end
end
close SKU_C_ENTITY_MEDIUM
deallocate SKU_C_ENTITY_MEDIUM
end
if @LEVEL_SKU_CAT=AND @V_SKU_UPPER<>'' AND @numSkuLevels >= 1
begin
VALUES(9000,@V_SKU_CAT,@V_SKU_CAT,0,0,0)
SELECT @item_cat_code=CAT_CODE FROM CATEGORIES WHERE rtrim(@lang_Item_value)=CAT_IDEN
INSERT INTO
VALUES(@item_cat_code,9000)
PRINT @
V_SKU_UPPER
DECLARE @upperLevelSQLString NVARCHAR(4000)
SET @upperLevelSQLString dbo.GET_UPPER_SKU_LEVEL_SQL_STRING( @existsCOLORID, @existsSIZEID, @existsCONFIGID,
erpCompany, @V_SKU_UPPER, @V_COLOR, @V_SIZE, @V_CONF, @lang_Item_value )
EXEC sp_executesql @upperLevelSQLString
declare SKU_C_ENTITY_UPPER cursor for
SELECT
DP_SKU
FROM
WHERE CAT_CODE
=9000
UNION
SELECT ITW_ITEM_ID
+'_UNDEF' AS NEWSKU,ITW_ITEM_ID,ITW_ITEM_ID
FROM
WHERE IV
.ITW_ITEM_ID NOT IN
select DISTINCT ITW_ITEM_ID
from
WHERE
V
.ITW_ITEM_ID=ITEMID
open SKU_C_ENTITY_UPPER
fetch next from SKU_C_ENTITY_UPPER into
begin
SET
@ITEM_DESC=''
SELECT
FROM
MBS_ITEM_DESC_VIEW
WHERE IDW_ITEM_ID
=@ITEM_IDEN
SET
@ITEM_CODE=-1
SELECT
FROM
BASE_ENTITIES
WHERE B_ENTITY_IDEN
=@T_ITEM_IDEN
if (@ITEM_CODE<>-1)
begin
SELECT
FROM
BASE_ENTITIES
INSERT INTO
BASE_ENTITIES
VALUES        ( @MAX_ENTITY_CODE, @SKU_IDEN'-', @ITEM_DESC9000, @PLANNER )
end
end
close SKU_C_ENTITY_UPPER
deallocate SKU_C_ENTITY_UPPER
end
SET
@LEVEL_SKU_CAT=@LEVEL_SKU_CAT+1
@V_SKU_CAT
end
CLOSE SKU_CATEGORIES
DEALLOCATE SKU_CATEGORIES
declare @num int
SELECT
@num count(*) FROM MBS_SKU_DIMENSIONS
if (@num=3)
begin
INSERT INTO
[SLAVA].[AXDB].[dbo].MBS_SKU_MAPPINGS([DP_SKU], [ITEM_ID], [START_ITEM_ID], [COLOR_ID], [SIZE_ID], [CONFIG_ID], [CAT_CODE], [DATA_AREA_ID])
SELECT DISTINCT ITW_ITEM_ID+'_UNDEF_UNDEF_UNDEF',ITW_ITEM_ID,ITW_ITEM_ID,'','','',0,@erpCompany
FROM MBS_ITEM_DIMENSION_VIEW DV
WHERE ITW_ITEM_ID NOT IN
SELECT ITEM_ID FROM [SLAVA].[AXDB].[dbo].MBS_SKU_MAPPINGS )
end
if (@num=2)
begin
INSERT INTO
SELECT DISTINCT ITW_ITEM_ID+'_UNDEF_UNDEF',ITW_ITEM_ID,ITW_ITEM_ID,'','','',0,@erpCompany
end
if (@num=1)
begin
INSERT INTO
SELECT DISTINCT ITW_ITEM_ID+'_UNDEF',ITW_ITEM_ID,ITW_ITEM_ID,'','','',0,@erpCompany
end
if (@num=0)
begin
INSERT INTO
[SLAVA].[AXDB].[dbo].MBS_SKU_MAPPINGS ([DP_SKU], [ITEM_ID], [START_ITEM_ID], [COLOR_ID], [SIZE_ID], [CONFIG_ID], [CAT_CODE], [DATA_AREA_ID])
SELECT DISTINCT ITW_ITEM_ID,ITW_ITEM_ID,ITW_ITEM_ID,'','','',0,@erpCompany
SELECT ITEM_ID FROM [SLAVA].[AXDB].[dbo].MBS_SKU_MAPPINGS)
end
Удостоверьтесь, что файл main_script.sql в каталоге приложения не поврежден.
Вопрос по модулю Расчеты с персоналом. Выплата заработной платы. Keks DAX: Функционал 7 28.12.2009 10:31
Вопрос по созданию отчета asd1274 DAX: Программирование 6 05.12.2008 21:44
Еще вопрос про покрытие по аналитикам в Сводном планировании rt2 DAX: Функционал 3 24.03.2006 18:56
расчеты с персоналом. НДФЛ. вопрос чайника shumelka DAX: Функционал 2 25.03.2004 11:36
Часовой пояс GMT +3, время: 12:46.
