Старый 14.03.2007, 13:27   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от Blog bot Посмотреть сообщение
Active Directory based login system of the Dynamics Ax 4.0 requires to change our logon to know the way your setup works for other logins. "runas" command that comes inbuilt with Window Xp and other higher version would be very helpful. Exectuing through GUI Right Click and Select Runas...
Открыл Америку...
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 10:50.
