Старый 12.04.2007, 13:00   #1
25,643 / 848 (80) +++++++
Arijit Basu: Elements changed between versions of Microsoft Dynamics AX
Источник: http://daxguy.blogspot.com/2007/04/e...rsions-of.html
The downloadable lists of changed elements compare the tables, classes and methods, configuration keys, and security keys from older versions of Microsoft Dynamics AX (formerly Microsoft Business Solutions Axapta) to the same elements in Microsoft Dynamics AX 4.0 SP1.
This information is provided to assist with estimating workload expenses before completing an upgrade. After you identify the elements that have changed between versions, you should use the Compare tool and Code Upgrade tool to determine how the element has been changed.
Very useful for DAX 3 --> DAX 4 Upgrades :)
Click to download {Requires Partnersource Logon}
Arijit Basu: Microsoft Dynamics AX Technology Webcast Series Blog bot DAX Blogs 0 12.01.2008 12:31
Dynamics AX: Microsoft Dynamics AX (DAX): Known Issues when upgrading to Microsoft Dynamics™ AX 4.0 - Arijit Basu | AX MVP Blog bot DAX Blogs 0 31.05.2007 03:30
Arijit Basu: Elements changed between versions of Microsoft Dynamics AX - {Download now available} Blog bot DAX Blogs 0 26.04.2007 14:10
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 06:22.
