Старый 03.05.2007, 18:04   #5
Zan is offline
Zan
Предлагаю сразу заполнить каким-нибудь непреметным значением пустые Labels.
За основу взял job от gl00mie
#AOT
static void AOTprintUpdateEnumValuesUnlabeled(Args _args)
    TreeNodeIterator    tnIterator;
    TreeNode            tnEnum,
                        tnEmunChild;
    DictEnum            dtEnum;
    boolean             bEnumIsOk;
    str                 strValueLabel;
    int                 i;
    int                 cnProcessed = 0;
    int                 cnUnlabeled = 0;
    int                 cnEnumsNotOk= 0;
    // zan 03.05.2007 -->
    int                 conElmUpd   = 3; //Label
    str                 properties,
                        labelValueNew = '-',
                        conValue;
    container           conProperties;
    // zan 03.05.2007 <--
    tnIterator  = TreeNode::findNode(#BaseEnumsPath).AOTiterator();
    while(true)
        tnEnum  = tnIterator.next();
        if(!tnEnum) break;
        cnProcessed++;
        dtEnum  = new DictEnum(tnEnum.applObjectId());
        if(!dtEnum)
            error(strfmt(@"Failed to create DictEnum object for '%1\%2' (objectId %3)!",
                         #BaseEnumsPath, tnEnum.AOTname(), tnEnum.applObjectId()));
            continue;
        bEnumIsOk = true;
        for(i=0; i<dtEnum.values(); i++)
            strValueLabel = dtEnum.index2Label(i);
            if(!strValueLabel)
                cnUnlabeled++;
                bEnumIsOk = false;
                warning(strfmt(@"%1::%2 (value %3)  has no label!",
                               dtEnum.name(), dtEnum.index2Symbol(i), dtEnum.index2Value(i)));
                if(labelValueNew)
                    tnEmunChild   = tnEnum.AOTfindChild(dtEnum.index2Symbol(i));
                    properties    = tnEmunChild.AOTgetProperties();
                    conProperties = str2con(properties,'\n');
                    conValue      = conpeek(conProperties,conElmUpd);
                    conValue     += labelValueNew;
                    conProperties = conpoke(conProperties, conElmUpd, conValue);
                    properties    = con2str(conProperties,'\n');
                    tnEmunChild.AOTsetProperties(properties);
                    tnEmunChild.AOTsave();
                    tnEnum.AOTsave();
                    //info(properties);
        if(!bEnumIsOk)
            cnEnumsNotOk++;
    info(strfmt(@"%1 base enums processed, %2 unlabeled enum values found in %3 enums", cnProcessed, cnUnlabeled, cnEnumsNotOk));
// gl00mie, 20070503 <--
query, баг, ax3.0
axStart: When is my Label file updated in AX? Blog bot DAX Blogs 8 28.01.2010 22:09
DynaMihamAX: Label import problem in Dynamics AX 4.0 Blog bot DAX Blogs 0 12.12.2008 13:05
axaptapedia: Label Blog bot DAX Blogs 0 03.12.2007 16:00
axaptapedia: Label Blog bot DAX Blogs 0 30.11.2007 20:41
axaptafreak: Label for Query Range cannot be modified (still) Blog bot DAX Blogs 2 25.07.2007 10:09
Часовой пояс GMT +3, время: 05:14.
