02.08.2007, 21:30 | #21 |
Какой-то диверсант поработал над формой SysSqlAdmin и отключил кнопку "Check/Synchronize".
02.08.2007, 22:00 | #22 |
tomb: AX 4.0 SP2 released
Источник: http://blogs.msdn.com/tomb/archive/2...-released.aspx
============== The new service pack for Microsoft Dynamics AX 4.0 has been released, with the very original name SP2. Some of the highlights are: · Support for 15 different new document AXDs in the Application Integration Framework. · Updates and bug fixes to functionality shipped in Microsoft Dynamics AX 4.0 Service Pack 1. Changes include areas such as Financials, BI & Reporting, Client, Cost Accounting, Customer Relationship Management, Developer & Partner Productivity Tools, Enterprise Portal, Inventory Management, Manufacturing, Master Resource Planning, Product Builder, Project Accounting, Application Object Server, and Shop Floor Control. Partners can download it on PartnerSource, customers can find it on CustomerSource Источник: http://blogs.msdn.com/tomb/archive/2...-released.aspx
03.08.2007, 11:29 | #23 |
16033 - Russian report generator performance was improved
Поставил СП2. Как ставил - предмет отдельного опуса, учитывая, что у меня Windows XP Home Edition.
Прочитал, что ускорена работа российского генератора отчётов. Открываю метод класса LedgerRRGOperationTurnoverCorrCredit_RU: X++: public AmountMST calc() { AmountMST sumTmp, corrTotal =0; while select m_AccountList { while select m_OffsetAccountList { while select AmountMST, AmountMSTSecond, TransType, OperationsTax, Correct, Dimension from m_LedgerTrans where m_LedgerTrans.AccountNum == m_AccountList.AccountNum && m_LedgerTrans.PeriodCode == PeriodCode::Regular && m_LedgerTrans.TransDate >= m_CalculateDateFrom && m_LedgerTrans.TransDate <= m_CalculateDateTo && m_LedgerTrans.Crediting == NoYes::Yes && m_LedgerTrans.BondBatch_RU && m_LedgerTrans.BondBatchTrans_RU exists join m_OffsetLedgerTrans where m_OffsetLedgerTrans.AccountNum == m_OffsetAccountList.AccountNum && m_OffsetLedgerTrans.PeriodCode == PeriodCode::Regular && m_OffsetLedgerTrans.TransDate == m_LedgerTrans.TransDate && m_OffsetLedgerTrans.Voucher == m_LedgerTrans.Voucher && m_OffsetLedgerTrans.Crediting == NoYes::No && m_OffsetLedgerTrans.BondBatch_RU == m_LedgerTrans.BondBatch_RU && m_OffsetLedgerTrans.BondBatchTrans_RU == m_LedgerTrans.BondBatchTrans_RU && m_OffsetLedgerTrans.RecId != m_LedgerTrans.RecId { if (this.checkTransaction(m_LedgerTrans.TransType, m_LedgerTrans.OperationsTax, m_LedgerTrans.Correct, m_LedgerTrans.Dimension, '')) { if (m_currencyForCalc == LedgerRRGCurrencyForCalc_RU::AmountMST) { sumTmp = m_LedgerTrans.AmountMST; } else { sumTmp = m_LedgerTrans.AmountMSTSecond; } corrTotal += (m_AccountList.ReverseSign ? (-1) : 1) * sumTmp; } } } } return -corrTotal; } |
03.08.2007, 11:59 | #24 |
Microsoft Dynamics
Вы не туда смотрите. Старые классы остались в GLS слое. Все модификации были сделаны в новых классах в GLP слое. Смотрите классы LedgerRRGOp_*.
Последний раз редактировалось AlexSD; 03.08.2007 в 12:31. Причина: орфографическая ошибка |
03.08.2007, 12:16 | #25 |
Точно Спасибо!
04.08.2007, 20:26 | #26 |
Для просмотра ссылки требуется регистрация на Партнерсорсе.
С уважением, glibs® |
За это сообщение автора поблагодарили: EVGL (4). |
04.08.2007, 21:53 | #27 |
29.08.2007, 17:05 | #28 |
Спасибо еще раз, glibs. Вот текст:
Possible Data Loss In The DOCUREF Table When Running Check/Synchronize in Microsoft Dynamics™ AX 4.0
When you perform the check synchronize process in Microsoft Dynamics™ Ax 4.0 or 4.0 SP1, and select every option but diagnostic under Administration | Periodic | SQL Administration, Microsoft Dynamics™ Ax will delete the content of the field Notes in the table DOCUREF for every record. In addition, check synchronize will show an incorrect type for the notes field, but that error reoccurs even if you delete the table in SQL and perform a synchronization to recreate the table. This issue doesn’t happen when doing just synchronization, only when using check/synchronize and check synchronize will try to drop object indexes that do not exist in SQL server. It is NOT RECOMMENDED to run the check/synchronize functionality in Microsoft Dynamics™ AX 4.0. This issue will be resolved in a future Microsoft Dynamics™ AX hot fix release by disabling the check/synchronize functionality. Watch for the hot fix to appear on the Hot Fixes released for Microsoft Dynamics™ AX 4.0 page. All synchronize activities should be performed from the AOT by right clicking on the data dictionary and choosing synchronize. Резюме: без функции "Проверить/синхронизировать" жить разработчику практически невозможно. Но использовать ее огульно для всех таблиц разом нельзя ни в коем случае. |
29.08.2007, 20:45 | #29 |
На здоровье. Кушайте, не обляпайтесь.
Между прочим, информация проскочила на международном так называемом community (то, что вместо technet-а соорудили). Так что имеет смысл его мониторить тоже. Там тоже интересный контент. Это, как говорится, "Хозяйке на заметку". Кажется, в прошлый раз до последнего абзаца я не дочитал. Действительно, проверку/синхронизацию замочили именно по этому поводу. Только я не понял. Они проверку/синхронизацию чинить собираются? Или решили ее истребить? А то я сейчас скажу, каким словом они называются.
29.08.2007, 20:53 | #30 |
29.08.2007, 21:30 | #31 |
Это я уже видел, спасибо. Кнопка Проверить/Синхронизировать теперь серая как для всех таблиц, так и для индивидуальной.
Я так понимаю, что теперь есть два пути: 1) Похоронить процедуру проверки/синхронизации, убрать кнопку, опционально уничтожить класс, который раньше ее выполнял, и останутся о ней только воспоминания. Опционально можно сделать по-ленивому (оставить все как есть сейчас). 2) Отремонтировать таки проверку/синхронизацию. Вот я и не понял из приведенного выше текста, каким путем пойдет Микрософт. О том, что данная функция крайне важна и полезна EVGL уже писал. Надеюсь, все и так знают. Это к тому, что я не от нефиг делать интересуюсь.
