Старый 24.10.2007, 14:59   #21
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Changes between Microsoft Axapta 3.0 and Microsoft Dynamics AX 4.0, and implications for upgrade
Record identification: Change of allocation principles - In Microsoft Dynamics AX 4.0 the record identification allocation has changed from per company to per table. This means that record identifications can no longer be assumed to be unique across a company. As a consequence, application code that refers to record identifications should be carefully reviewed and code that relies on unique allocation within a company must be modified.
ax4.0, recid
if (record) vs if (record.RecId) kashperuk DAX: Программирование 18 27.11.2008 18:53
Глюк с RecId в Ax 4.0 npokypatop DAX: Программирование 5 22.07.2008 13:08
поля, содержащие RecId somebody DAX: Программирование 15 16.05.2008 17:50
aEremenko: Дефрагментация RecID Blog bot DAX Blogs 2 06.03.2007 22:25
Два RecId у одной записи таблицы sparur DAX: Программирование 33 18.12.2006 15:56
Часовой пояс GMT +3, время: 13:57.
