Старый 26.04.2008, 04:21   #1
25,751 / 851 (80) +++++++
To find objects in AOT with particular properties
Источник: http://alexvoy.blogspot.com/2008/04/...articular.html
Sometimes I need to find objects in AOT with particular properties. Find tool (Ctrl-F) works great when you set Containing text field correctly.
In the following case I tried to find all tables in AOT with Temporary property set to Yes.
Dynamics AX FAQ: How to find an AOT object by its property? Blog bot DAX Blogs 2 07.11.2008 12:54
axStart: How to find line of code with a question mark in your AOT. Blog bot DAX Blogs 0 16.04.2008 22:05
C# and AX Development: How to delete AOT objects (AX/Axapta) Blog bot DAX Blogs 0 13.12.2007 19:50
daxmy: AOT Find function Blog bot DAX Blogs 0 17.08.2007 01:23
Dynamics AX Geek: cross-references & find Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 21:19.
