Старый 20.06.2008, 17:05   #1
25,751 / 851 (80) +++++++
axStart: Ax product version check
Источник: http://axstart.spaces.live.com/Blog/...C0A0!350.entry
This is a list of all released Versions of AX. Additional a script is added, to check the version of your current installation.  The numbers in this list are from the versions running on my laptop so please correct me, when there is wrong number.
Release
Service Pack
Client
Server
Application Version
3.0
SP3
3.0.1951.3730
3.0.1951.3730
514-193 SP3/OP023-71
3.0
SP4
3.0.1951.4060
3.0.1951.4060
514-320 SP4/OP023-196
3.0
SP5
3.0.1951.5160
3.0.1951.5160
514-513 SP5/OP023-379
3.0
SP6
3.0.1951.7609
3.0.1951.7609
514-859 SP6/OP023-659
3.0
KR1
3.0.1951.6710
3.0.1951.6710
Not applicable
3.0
KR2
Sorry not on my laptop
Not applicable
3.0
KR3
3.0.1951.7609
3.0.1951.7609
Not applicable
4.0
SP1
4.0.2163.0
4.0.2163.0
4.0.2163.0
4.0
SP2
4.0.2501.116
4.0.2501.116
4.0.2501.116
5.0
You can also check the client and server version without starting AX.  Look at the properties of the file ax32.exe and ax32serv.exe. The version number is also visible on this place. If I want to check outside AX the application version of AX. I use this trick look at the file size of the axSyp.aod and axGLP.aod
Release
Service pack
axSyp.aod
axGlp.aod
3.0
SP3
30.370 KB
12.168 KB
3.0
SP4
33.800 KB
14.762 KB
3.0
SP5
39.360 KB
16.144 KB
3.0
SP6
45.585 KB
15.166 KB
4.0
SP2
34.357 KB
The next job shows your server version and client version number.
static void buildTest(Args _args)
    KernalTest  KernalTestClient = CLassFactory::makeObjectOnClient(classnum(KernalTest));
    KernalTest  KernalTestServer = CLassFactory::makeObjectOnServer(classnum(KernalTest));
    info(KernalTestClient.buildno());
    info(KernalTestServer.buildno());
Class KernalTest
str buildNo()
    return strfmt('%1 %2',xGLobal::clientKind(), xInfo::buildNo());
mfp: Dynamics AX 2009 Version Control Interview Blog bot DAX Blogs 0 28.01.2009 12:05
axStart: Microsoft Dynamics AX 2009 White Paper: Team Foundation Server Version Control Setup Blog bot DAX Blogs 0 27.07.2008 13:06
Dynamics AX: Product Management with Dynamics AX Blog bot DAX Blogs 1 15.02.2008 11:47
Часовой пояс GMT +3, время: 23:13.
