Старый 08.08.2008, 12:08   #3
DmitryS is offline
DmitryS
В лог пишет следующее:
Axapta Crash Dump File for Axapta build 2501.116 (Jul 11 2007 09:54:38)
Dumped : Thu Aug 07 17:47:27 2008
Crash : Exception 0xc0000005 caught (unspecified) in thread 0x1748 of process 0x1118.
--# FV EIP----- RetAddr- FramePtr StackPtr Symbol
0 .V 01223ebe 011cb41c 0022f840 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
1 .V 011cb41c 011cb431 0022f85c 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
2 .V 011cb431 01242aef 0022f874 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
3 .V 01242aef 012434dd 0022f8b8 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
4 .V 012434dd 011f7906 0022f8c4 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
5 .V 011f7906 011f7cdf 0022f8f4 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
6 .V 011f7cdf 011c049d 0022f900 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
7 .V 011c049d 0124b25f 0022f934 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
8 .V 0124b25f 0124b59b 0022f984 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
9 .V 0124b59b 0118caf8 0022f9dc 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
10 .V 0118caf8 01154505 0022fb8c 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
11 .V 01154505 0148fed7 0022fb94 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
12 .V 0148fed7 01171022 0022fbc4 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
13 .V 01171022 0116c710 0022fbe8 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
14 .V 0116c710 7739b6e3 0022fc34 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
15 .V 7739b6e3 7739b874 0022fc60 00228c48 LoadCursorW +19701 bytes
Decl: LoadCursorW
Mod: USER32[USER32.dll], base: 77380000h
16 .V 7739b874 7739bfce 0022fcd8 00228c48 LoadCursorW +20102 bytes
Decl: LoadCursorW
17 .V 7739bfce 7739bf74 0022fd08 00228c48 CallWindowProcW +117 bytes
Decl: CallWindowProcW
18 .V 7739bf74 0116adfb 0022fd28 00228c48 CallWindowProcW +27 bytes
19 .V 0116adfb 0116aeb1 0022fd44 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
20 .V 0116aeb1 7739b6e3 0022fd88 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
21 .V 7739b6e3 7739b874 0022fdb4 00228c48 LoadCursorW +19701 bytes
Decl: LoadCursorW
22 .V 7739b874 7739ba92 0022fe2c 00228c48 LoadCursorW +20102 bytes
Decl: LoadCursorW
23 .V 7739ba92 7739bad0 0022fe94 00228c48 TranslateMessageEx +269 bytes
Decl: TranslateMessageEx
24 .V 7739bad0 01159fcc 0022fea4 00228c48 DispatchMessageW +15 bytes
Decl: DispatchMessageW
25 .V 01159fcc 0115b4ac 0022fed8 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
26 .V 0115b4ac 0116aab1 0022ff10 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
27 .V 0116aab1 0151e4bc 0022ff28 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
28 .V 0151e4bc 77e6f23b 0022ffc0 00228c48 Mod: Ax32[Ax32.exe], base: 01000000h
29 .V 77e6f23b 00000000 0022fff0 00228c48 ProcessIdToSessionId +521 bytes
Decl: ProcessIdToSessionId
Mod: kernel32[kernel32.dll], base: 77e40000h
Stackdump exit code 487 (Attempt to access invalid address)
ax4.0
Как сильно модифицировано ваше приложение Аксапты? mazzy DAX: Прочие вопросы 30 14.04.2011 17:26
Как программно отправить сообщение группе пользователей demon46 DAX: Функционал 7 01.04.2008 14:57
Проблема с лицензией, при загрузке, после ввода пороля появляется сообщение 3oppo DAX: Программирование 3 07.10.2005 08:01
Странное сообщение Axapta. Spider DAX: Прочие вопросы 5 11.07.2005 16:13
Часовой пояс GMT +3, время: 22:11.
