Старый 28.08.2008, 15:05   #1
25,643 / 848 (80) +++++++
msdynamicsax: selecting data from multiple companyaccounts
Источник: http://msdynamicsax.wordpress.com/20...mpanyaccounts/
Some of you might have heard about the new reserved word in x++ called crossCompany. It enables you to select data across multiple companies in Ax without the use of changecompany (which I hated)
Anyway, this is an example of how it works:
static void getTotalLineAmount(Args _args)
    SalesLine       salesLine;
    container       companies = ['dmo', 'dm2', 'dm3']; // specify the companyaccounts to select from
    select crossCompany : companies sum(LineAmount) from salesLine;
    info (num2str(salesLine.LineAmount,0,2,1,2));
Solutions Monkey: Programatically reading data from AxDataSourceControl Blog bot DAX Blogs 1 07.11.2008 09:17
msdynamicsax: Upgrading a database from Ax 4.0 SP1 to Ax 2009 Blog bot DAX Blogs 1 13.08.2008 14:02
msdynamicsax: Dynamics Ax 2009 Demo Data Blog bot DAX Blogs 0 05.07.2008 13:09
msdynamicsax: Multiple time zones Blog bot DAX Blogs 0 15.05.2008 22:05
Часовой пояс GMT +3, время: 17:56.
