Старый 17.04.2002, 11:41   #4
Роман Кошелев is offline
Роман Кошелев
Продавец игрушек
Аватар для Роман Кошелев
433 / 73 (3) ++++
Нашёл:
<hr>
<h3><span style="font-weight: bold;">Indirect access</span></h3>
Defining indirect access is an important part of granting feature key permissions to a user group.
Indirect access is used to grant users modify or view access to information from modules where they have no direct access.
Direct and indirect access are validated at different times and on different application objects. Direct access is validated on <span style="font-style: italic;">menu items</span>. The menu item can be placed in a menu on the <span style="font-weight: bold;">Main menu</span>,<span style="font-weight: bold;"> </span>or as a menu button on a form's menu button. Indirect access is validated on form and report controls. The practical use and purpose is best described using an example.
<h3>Indirect access example</h3>
Martin works in customer service as an order taker. This means that he should have access to the order module, both direct and indirect. He does not do inventory management so he has no access to the inventory module. However, this is not a workable situation because Martin will not be able to take orders if he does not know what
is on stock. To resolve the conflict, Martin’s indirect access to the Inventory module is set to <span style="font-weight: bold;">Full control</span>.
This will allow him to give him look up information in the inventory table from the sales order form but he will <span style="font-style: italic;">not</span> have access to the inventory module from the main menu. If the indirect access was only set to <span style="font-weight: bold;">Read</span>, Martin would be able to see inventory items on existing orders. He would not be able to modify them, or to add new ones.
С уважением, Роман Кошелев.
права доступа, ax2.5
Покупка Аксапта... Лицензионные ключи и модули edd DAX: Прочие вопросы 20 20.12.2006 14:33
Как загрузить лицензии чтобы не слетели конф. ключи? MironovI DAX: Администрирование 2 20.01.2006 12:42
Абстрактный классификатор Maxim Gorbunov DAX: Программирование 52 17.01.2005 13:52
Функциональные ключи bms DAX: Функционал 1 30.10.2003 16:07
Проблема при настройке прав пользователей на функциональные ключи? Мирослав DAX: Администрирование 1 17.07.2002 15:42
Часовой пояс GMT +3, время: 22:21.
