Старый 17.10.2008, 12:13   #1
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Обращение к CrmService
Стандартный код выдает ошибку
using System;
using System.Data;
using System.Configuration;
using System.Collections;
using System.IO;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.Xml;
using CrmSdk;
using CrmSdk.Discovery;
public partial class UpdateActivity : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
Response.Clear();
Response.ContentType = "text/xml";
CrmAuthenticationToken token = new CrmAuthenticationToken();
token.AuthenticationType = 0;
token.OrganizationName = "Samarasoft";
CrmService crmService = new CrmService();
crmService.CrmAuthenticationTokenValue = token;
crmService.Credentials = System.Net.CredentialCache.DefaultCredentials;
AppSettingsReader appSettings = new AppSettingsReader();
crmService.Url = appSettings.GetValue("CrmSdk.CrmService", Type.GetType("System.String")).ToString();
task my_task = new task();
my_task.subject = "my_task_1";
Guid t_guid = new Guid("A64664F4-E699-DD11-B4E0-00A0C5B316E9");
Owner t_owner = new Owner();
t_owner.Value = t_guid;
t_owner.type = EntityName.systemuser.ToString();
my_task.ownerid = t_owner;
Guid accountId = crmService.Create(my_task);
Ошибка идет на шаге Guid accountId = crmService.Create(my_task); такая:
Exception information:
Exception type: SoapException
Exception message: System.Web.Services.Protocols.SoapException: Сервер не распознал значение заголовка HTTP SOAPAction: http://schemas.microsoft.com/crm/200...ervices/Create.
в System.Web.Services.Protocols.Soap11ServerProtocolHelper.RouteRequest()
в System.Web.Services.Protocols.SoapServerProtocol.Initialize()
в System.Web.Services.Protocols.ServerProtocol.SetContext(Type type, HttpContext context, HttpRequest request, HttpResponse response)
в System.Web.Services.Protocols.ServerProtocolFactory.Create(Type type, HttpContext context, HttpRequest request, HttpResponse response, Boolean& abortProcessing)
Request information:
Request URL: http://crm:1001/UpdateActivity.aspx?...Mode=Completed
Request path: /UpdateActivity.aspx
User host address: 192.168.100.62
User:
Is authenticated: False
Authentication Type:
Thread account name: NT AUTHORITY\NETWORK SERVICE
Что то я уже всю голову сломал в чем дело - стандартная конструкция не работает
Подскажите в чем может быть дело...
Сергей Осипов, MCTS:SQL Server 2005, ООО "Программные технологии", Самара
Старый 17.10.2008, 12:46   #2
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
В других конструкциях он такое же выдает, например
activitypointer act = (activitypointer)crmService.Retrieve(EntityName.activitypointer.ToString(), idGuid, new AllColumns());
Какой то неправильный у меня сервис получился, а в чем причина не пойму...
Старый 17.10.2008, 14:45   #3
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Это вы скопировали из дебаггера? Приведите пожалуйста стек трасировки из лога ошибок сервера.
Старый 17.10.2008, 16:46   #4
Гуревич Денис is offline
Гуревич Денис
228 / 67 (3) ++++
Вообще-то, поскольку у Вас aspx-страничка, то я бы для начала вот это прочитал:
http://msdn.microsoft.com/en-us/library/cc151050.aspx
За это сообщение автора поблагодарили: sergeyjb (1).
Старый 19.10.2008, 12:16   #5
maclai is offline
maclai
Сергеи, посмотрите http://localhost:<порт>/sdk/list.aspx. Похоже,
при создании task activityid является обязателним атрибутом.
Старый 20.10.2008, 08:14   #6
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
maclai:
Интересная страница, не знал о ее существовании.
Действительно поле activityid отмечено как Required For Grid.
Удивило то, что ownerid не помечено как обязательное, хотя на форме поле "ответственный" стоит с красной звездочкой.
Гуревич Денис:
Спасибо за ссылку, сейчас попробую как там пишут. Есть подозрение судя по ошибкам что с самим сервисом не порядок а не с набором отправляемых полей. Я ожидал бы другой ошибки если обязательное поле отсутствовало.
Хотя попробую все варианты.
Артем, это часть целого сообщения в системном журнале: "Журналы Windows - Приложение".
Если есть отдельный журнал ошибок CRM сервера то подскажите где его посмотреть.
А из системного полный текст ошибки (точнее предупреждения):
Код:
Event code: 3005
Event message: Возникло необработанное исключение.
Event time: 20.10.2008 8:47:52
Event time (UTC): 20.10.2008 3:47:52
Event ID: 907e722b17074104b8b6d5540dbae94c
Event sequence: 6
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/3/ROOT-1-128689480638620121
Trust level: Full
Application Virtual Path: /
Application Path: C:\inetpub\Infrastructure\
Machine name: SRV-CRM-01
Process information:
Process ID: 1828
Process name: w3wp.exe
Account name: NT AUTHORITY\NETWORK SERVICE
User:
Thread information:
Thread ID: 5
Is impersonating: False
Stack trace: в System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
в System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
в CrmSdk.CrmService.Create(BusinessEntity entity) в c:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\root\5c7d8db1\29570109\App_WebReferences.wh6ss6eb.0.cs:строка 204
в UpdateActivity.Page_Load(Object sender, EventArgs e) в c:\inetpub\Infrastructure\UpdateActivity.aspx.cs:строка 64
в System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
в System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
в System.Web.UI.Control.OnLoad(EventArgs e)
в System.Web.UI.Control.LoadRecursive()
в System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Custom event details:
Старый 20.10.2008, 08:32   #7
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Добавление конструкции для activityid проблему не решило, но на будущее лишним явно не будет.
Key t_key = new Key();
t_key.Value = new Guid();
my_task.activityid = t_key;
Сейчас буду с Impersonate разбираться.
Не зря в логе:
Не думал сначала что обращение к сервису с ASPX страницы отличается от стандартного примера в SDK. Предполагал что они в расчете на WEB доступ пример писали.
Старый 20.10.2008, 14:09   #8
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Сделал по примеру как в ссылке для ASP:
Код:
using System;
using Microsoft.Win32;
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
    public string orgname;
    public string crmurl;
    public string metaurl;
        RegistryKey regkey = Registry.LocalMachine.OpenSubKey("SOFTWARE\\Microsoft\\MSCRM");
        string ServerUrl = regkey.GetValue("ServerUrl").ToString();
        crmurl = ServerUrl + "/2007/crmservice.asmx";
        metaurl = ServerUrl + "/2007/metadataservice.asmx";
        orgname = "Samarasoft";
        using (new CrmImpersonator())
            CrmAuthenticationToken token;
            token = CrmAuthenticationToken.ExtractCrmAuthenticationToken(Context, orgname);
            token.OrganizationName = orgname;
            CrmService service = new CrmService();
            service.Credentials = System.Net.CredentialCache.DefaultCredentials;
            service.CrmAuthenticationTokenValue = token;
            service.Url = crmurl;
        Response.Write("Done");
Код new CrmImpersonator() вызывает ошибку обращения к несуществующему токену...
Код:
Event code: 3005
Event time: 20.10.2008 14:50:28
Event time (UTC): 20.10.2008 9:50:28
Event ID: a22bbfc8755f4f539d4a8ad4786cebed
Event sequence: 47
Event occurrence: 3
Application domain: /LM/W3SVC/4/ROOT-8-128689694218393361
Trust level: Full
Application Path: C:\inetpub\asp_automate\
Process ID: 5768
Exception type: InvalidOperationException
Exception message: OpenThreadToken failed with hr = 1008
Request URL: http://crm:1003/UpdateActivity.aspx?sState=Update
User:
Thread information:
Thread ID: 7
Stack trace: в Microsoft.Crm.Sdk.CrmImpersonator.Impersonate()
в UpdateActivity.Page_Load(Object sender, EventArgs e) в c:\inetpub\Asp_automate\UpdateActivity.aspx.cs:строка 33
Старый 20.10.2008, 17:07   #9
Гуревич Денис
228 / 67 (3) ++++
В web.config'е Вашего приложения должно быть:
<identity impersonate="true"/>
Есть?
Старый 22.10.2008, 12:11   #10
maclai is offline
maclai
Добавление этого кода:
[quote=sergeyjb;180050]Добавление конструкции для activityid проблему не решило, но на будущее лишним явно не будет.
my_task.activityid = t_key;]
даст вам гуид null, что само по себе является ошибкой.
Если сама сущность создается через создание ее гуида, как компонент вебсервиса - значит или не все условия генерации выполняются, или генератор (сервис) используется не верно...
Я сам ломаю голову над своим generic sql erorr... если добьешь - черкни, в чем там дело было
Старый 22.10.2008, 13:44   #11
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Так надо (проверить пока не могу)?:
t_key.Value = NewGuid();
Судя по описанию должен дать новый Гуид
Guid.NewGuid Method - This is a convenient static method that you can call to get a new Guid
У меня проблема ни с generic sql erorr (до этого не доходит пока даже), а с авторизацией...
Не было <identity impersonate="true"/> - поставил...
Теперь надо с настройками IIS7 на стороне сервера разобраться: с пулами приложений (мое связано с DefaultAppPool сейчас) и "проверка подлинности" (у меня включены на этом узле "Олицетворение ASP.NET" и "Проверка подлинности Windows").
Сейчас браузер выдает ошибку
"Ошибка HTTP 500.24 - Internal Server Error
Обнаружены значения параметров ASP.NET, которые неприменимы в интегрированном режиме управляемого конвейера."
Так что до проблем с пустым Гуидом еще как до луны
Старый 23.10.2008, 14:55   #12
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
А какие возможны варианты запрограммировать поведение ISV кнопки на форме? Кроме как через ASP страницу? Или это единственный метод?
Старый 27.10.2008, 16:27   #13
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Сообщение от sergeyjb Посмотреть сообщение
Весь функционал, который требуется от кнопки - выносить в Java Script, но с дебагом - намучаетесь конечно...
А какой именно функционал от этой кнопки требуется?
Старый 28.10.2008, 13:20   #14
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Вопрос в общем - о возможностях.
А от данной кнопки в частности требуется только смена статуса активности через срм-сервис чтобы воркфлоу видела эти изменения.
Старый 28.10.2008, 14:57   #15
Артем Enot Грунин
Сергей, возможно более подробную информацию об ошибке вы получите из логов сервера. Вот статья о том как можно их включить: http://support.microsoft.com/kb/907490/en-us. В своё время я так и отлаживался, так как в дебагер валится лишь общая ошибка веб сервиса.
Старый 29.10.2008, 07:23   #16
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Спасибо Артем, а то с отладкой мне трудновато
Старый 29.10.2008, 13:58   #17
Артем Enot Грунин
Помогло проблему устранить?
Старый 30.10.2008, 14:30   #18
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Я сейчас переключился на интеграцию с шарпоинтом экстренно, через пару дней к этим кнопкам вернусь - тогда и опробую.
Тут вопрос возник с плагином на удаление акаунта.
На первой же строке валиться, причем такой же плагин на крейт акаунта работает.
Выдает ошибку:
Не удалось привести тип "Microsoft.Crm.Sdk.Moniker" объекта к типу "Microsoft.Crm.Sdk.DynamicEntity".
Что эта ошибка вообще означает? И почему при крейте проблем с приведением у него нет?
Выдает такое как на пре- так и пост-срабатываение.
Есть какая-то особенность обращения к объекту, вызвавшему плагин на удаление?
Код:
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
using ShPAccountDeletePlugin.st2;
namespace ShPAccountDeletePlugin
    public class UpdateAccountOnDelete : IPlugin
        public void Execute(IPluginExecutionContext context)
            DynamicEntity entity = (DynamicEntity)context.InputParameters.Properties[ParameterName.Target];
Старый 30.10.2008, 14:50   #19
Артем Enot Грунин
Видимо это и означает - типовой class cast. Properties[ParameterName.Target] имеет тип Moniker а не DynamicEntity. Почему - вопрос хороший.
Старый 30.10.2008, 15:01   #20
Артем Enot Грунин
Из опыта работы с CRM 3.0... Плагины (тогда еще колауты) событий создания и изменения тогда тоже оперировали DynamicEntity, а вот события смены состояния и удаления, по какой-то идиотской логике получали лишь id и имя сущности. Теперь и то и другое содержится в классе Moniker. Видимо вам придется вычитывать объект самостоятельно. Печально, но Microsoft последовательна в своем идиотизме.
Быстродействие CrmService Bakai Madybaev Dynamics CRM: Разработка 16 21.03.2009 22:57
Обращение к полю сущности MFCшный Wizard Dynamics CRM: Разработка 28 12.02.2009 14:35
аутентификация crmService if_maks Dynamics CRM: Разработка 2 25.12.2008 11:52
Обращение! - Ответственный контакт? AlekseyS Dynamics CRM: Разработка 1 09.09.2008 13:04
Обращение: невозможно добавить Контракт Lazarus Dynamics CRM: Функционал 2 01.07.2008 13:02
Часовой пояс GMT +3, время: 16:17.
