Старый 10.12.2008, 11:34   #7
Ievgenii is offline
Ievgenii
Аватар для Ievgenii
111 / 113 (4) +++++
Event Log естественно смотрели. Собственно, значимых сообщений 2:
Первое:
Object Server 01: SQL diagnostics: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified. Connect information was: Userid = [], Database = [DynamicsAx1], Server = [(local)], DSN = [], Other = []
Второе:
Object Server 01: Fatal SQL condition during login. Error message: "[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified"
Dear Xshaman,
Please go to Control Panel ->Administration Tools ->Data Sources (ODBC) ->Drivers
For SQL 2005 you will have SQL Native Client driver
For SQL 2008 you will have SQL Server Native Client 10.0
Axapta is looking for the first one, during the establishing connection to AOS - that's why you have such errors in App Log.
Thx,
Ievgenii Korovin| Dynamics Ax SCM| Microsoft Corp| http://blogs.msdn.com/DynamicsAxSCM/
За это сообщение автора поблагодарили: xshaman (1), zZ_TOP_Zz (1).
ax2009, native client, sql 2008, совместимость
Dynamics AX: SQL Sever 2008 - Performance with Dynamics AX 2009 - Resource Governor Blog bot DAX Blogs 0 23.01.2009 22:05
Dynamics AX: Why upgrade to SQL Server 2008 with DAX 2009? Blog bot DAX Blogs 0 16.10.2008 06:24
jinx: Microsoft Dynamics AX 2009, Windows Server 2008 und SQL Server 2008 Blog bot DAX auf Deutsch 0 12.10.2008 20:10
msdynamicsax: DAX 2009 and MS SQL 2008 Blog bot DAX Blogs 0 09.08.2008 14:05
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Часовой пояс GMT +3, время: 09:08.
