#3 |
MVP
hy Kashperuk,
You can use executequery on theax query class, but I was not able to get a join. I have talked to MS about it, joins for OLAP cubes was possible not for the .net connector. They suggest a sql query to the AX DB, This is to my opinion no option, and only the AOS should connect to the DB.
MVP |
