#3 |
LOG
log:
--- End of inner exception stack trace ---, Error, AbortRetryIgnore, Option1 13:27:41| Info| InputResult: Retry 13:27:41| Error| System.Exception: Action Microsoft.Crm.Setup.Exchange.InstallServiceAction failed. - --> System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at System.Int32.Parse(String s, IFormatProvider provider) at System.Diagnostics.PerformanceCounterLib.GetStringTable(Boolean isHelp) at System.Diagnostics.PerformanceCounterLib.get_NameTable() at System.Diagnostics.PerformanceCounterLib.get_CategoryTable() at System.Diagnostics.PerformanceCounterLib.CategoryExists(String machine, String category) at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName, String machineName) at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName) at Microsoft.Crm.Tools.Email.Agent.EmbeddedInstaller.Install(IDictionary stateSaver) at System.Configuration.Install.Installer.Install(IDictionary stateSaver) at System.Configuration.Install.AssemblyInstaller.Install(IDictionary savedState) at Microsoft.Crm.Setup.Exchange.InstallServiceAction.Do(IDictionary parameters) at Microsoft.Crm.Setup.Common.Action.ExecuteAction(Action action, IDictionary parameters, Boolean undo) Последний раз редактировалось Kosta100; 03.03.2009 в 15:22. Причина: bad |
