Старый 29.04.2009, 12:48   #1
Camena is offline
Camena
Ошибка при открытии отчета
Добрый день!
У некоторых пользователей при попытке открытия отчета выводится следующее сообщение об ошибки:
An error has occurred during report processing. (rsProcessingAborted)
Cannot create a connection to data source 'TT'. (rsErrorOpeningConnection)
For more information about this error navigate to the report server on the local server machine, or enable remote errors
В логах пишется следующее:
e ERROR: Throwing Microsoft.ReportingServices.Diagnostics.Utilities.ReportServerDatabaseUnavailableException: The report server cannot open a connection to the report server database. A connection to the database is required for all requests and processing., ;
Info: Microsoft.ReportingServices.Diagnostics.Utilities.ReportServerDatabaseUnavailableException: The report server cannot open a connection to the report server database. A connection to the database is required for all requests and processing. ---> System.Data.SqlClient.SqlException: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Connect(ServerInfo serverInfo, SqlInternalConnectionTds connHandler, Boolean ignoreSniOpenTimeout, Int64 timerExpire, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity, SqlConnection owningObject)
at System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, Int64 timerExpire, SqlConnection owningObject)
at System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(String host, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, Int64 timerStart)
at System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
at System.Data.SqlClient.SqlConnection.Open()
at Microsoft.ReportingServices.Library.ConnectionManager.OpenConnection()
--- End of inner exception stack trace ---
Пользователи добавлены в AD группу ReportingGroup, с этим проблем не должно быть. Соединение активно, так как большая часть пользователей открыть отчет все же может.
В чем причина ошибки? И почему возникает только у "избранных"?
Спасибо.
crm, открытие отчета, отчет, ошибка
Ошибка при загрузке функций Microsoft Dynamics CRM Talisman2005 Dynamics CRM: Администрирование 7 26.08.2008 21:21
Ошибка при попытке доступа к отчетам keensky Dynamics CRM: Администрирование 5 14.07.2008 20:17
Ошибка при добавлении отчета e.pasechny Dynamics CRM: Администрирование 5 11.12.2007 14:00
Загрузка отчета в MS SRM faust Dynamics CRM: Функционал 4 01.11.2006 11:13
после публикации отчета через CRM он перестает правильно работать kras Dynamics CRM: Администрирование 8 30.08.2006 11:11
Часовой пояс GMT +3, время: 19:15.
