Старый 28.05.2009, 11:38   #1
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
var passed = location.search;
phonecallid = passed.substring(5,41);
var xml = "<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
GenerateAuthenticationHeader()+
"<soap:Body>"+
"<Execute xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<Request xsi:type='SetStatePhoneCallRequest'>"+
"<EntityId>"+phonecallid+"</EntityId>"+
"<PhoneCallState>Completed</PhoneCallState>"+
"<PhoneCallStatus>-1</PhoneCallStatus>"+
"</Request>"+
"</Execute>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/200...ervices/Update");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
alert(msg);
// Display a confirmation message and open the updated contact.
else
alert("Contact with id = "+phonecallid+" successfully updated.");
window.open("/activities/phone/edit.aspx?id={"+phonecallid+"}");
Вот и ошибочка. Метод то Execute...
Замените
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Update");
на
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Execute");
Принудительное закрытие этапа сделки bstan Dynamics CRM: Функционал 4 22.03.2009 12:14
Закрытие Ввозможной сделки maxim_ufa Dynamics CRM: Функционал 9 29.12.2008 18:24
Ответственный за Звонок и возможность преобразования Звонка в сделку Lazarus Dynamics CRM: Функционал 3 11.12.2008 10:43
Торможение CRM после апгоейда с версии 3 на 4 Talisman2005 Dynamics CRM: Администрирование 24 26.06.2008 16:05
автоматическое закрытие действий в Sales Process glad Dynamics CRM: Функционал 4 26.07.2006 07:49
Часовой пояс GMT +3, время: 19:14.
