Старый 16.09.2003, 13:55   #4
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Должно работать.
static void Job4(Args _args)
Connection conn;
Statement Stmt;
ResultSet rslt;
int start_t;
LedgerTrans tblLedgerTrans;
InventTrans tblInventTrans;
//BSL_LockSPAccount tblLocksSP;
Str parseQuery()
Str SQLQuery "EXEC sp_BSL_Account20    ";
//SQLQuery +="'tst','01/02/2003','02/02/2003'";
SQLQuery +="'tst','20030201','20030202'";
    return
SQLQuery;
//super();
start_t timenow();
conn = new UserConnection();
Stmt conn.createStatement();
ttsBegin;
//select forupdate tblLocksSP;
        //tblLocksSP.UserId = CurUserId ( );
        //tblLocksSP.insert();
        /*Âûçîâ ïðîöåäóðû*/
rslt Stmt.executeQuery(parseQuery());
         while(
rslt.next())
info(strfmt("%1    %2     %3",rslt.getReal(1),rslt.getString(2),rslt.getString(3)) );
//tblLocksSP.delete();
ttsCommit;
Stmt.close();
rslt.close();
info(strfmt("Çàòðà÷åíî âðåìÿ %1 ñ.",timenow()-start_t));
SET QUOTED_IDENTIFIER ON
GO
SET ANSI_NULLS ON
GO
ALTER  PROCEDURE sp_BSL_Account20
@dataAreaId         varchar(255), -- Компания для расчета
@fromDateVarchar     varchar(255), -- Дата начала (строкапериода расчета
@toDateVarchar         varchar(255) -- Дата конца (строкапериода расчета
AS
set nocount on
set ansi_warnings off
if object_id('BSL_Account20'is not null
    DROP TABLE BSL_Account20
SELECT LEDGERTRANS
.ACCOUNTNUM,LEDGERTRANS.AMOUNTMSTLEDGERTRANS.TRANSDATELEDGERTRANS.VOUCHER
SELECT MAX(InventTrans.TransRefId
FROM InventTrans
    WHERE
        InventTrans
.Voucher LedgerTrans.Voucher AND InventTrans.DateFinancial LedgerTrans.TransDate OR
InventTrans.VoucherPhysical LedgerTrans.Voucher AND InventTrans.DatePhysical Ledgertrans.TransDate) AS Source
INTO BSL_Account20
FROM LEDGERTRANS
WHERE
((LEDGERTRANS.ACCOUNTNUM ' 20.110' OR
LEDGERTRANS.ACCOUNTNUM ' 20.120' OR
LEDGERTRANS.ACCOUNTNUM ' 20.130' OR
LEDGERTRANS.ACCOUNTNUM ' 20.210' OR
LEDGERTRANS.ACCOUNTNUM ' 20.220' OR
LEDGERTRANS.ACCOUNTNUM ' 20.310' OR
LEDGERTRANS.ACCOUNTNUM ' 20.320' OR
LEDGERTRANS.ACCOUNTNUM ' 20.410' OR
LEDGERTRANS.ACCOUNTNUM ' 20.420')
AND (
LEDGERTRANS.TransDate <= @toDateVarchar
AND LEDGERTRANS.TransDate >= @fromDateVarchar))
AND (
LEDGERTRANS.DataAreaId = @dataAreaId)
CREATE INDEX i_AccountNum ON BSL_Account20 (AccountNum);
CREATE INDEX i_LedgerTrans ON BSL_Account20 (Source);
SELECT SUM (AmountMST) AS SumResultAccountNumSource FROM BSL_Account20 GROUP BY AccountNumSource
Вызов метода базового класса Eldar9x DAX: Программирование 15 22.03.2008 19:10
Вызов экспортируемой функции DLL Jabberwocky DAX: Программирование 8 12.09.2006 17:20
SQL Profiler не показывает процедуры!SOS! naomy DAX: Программирование 13 28.09.2005 14:33
Хранимые процедуры и производительность vey DAX: Администрирование 13 17.06.2005 10:56
Как результат выполнения хранимой процедуры поместить в Grid? Yuri Safronov DAX: Программирование 1 28.08.2002 12:38
Часовой пояс GMT +3, время: 13:54.
