Старый 28.08.2009, 21:15   #6
Roman08 is offline
Roman08
Задача - создать связанный с opportunity объект сущности tcc_oppmonthly при измененении opportunity. Поле связи - tcc_monthlydetailsid.
//values for fields - заготовка, мне надо разделить значение поля estimatedvalue на некое значение и записать результат в поле tcc_value вновь создаваемой сущности.
Код:
using System;
using System.Collections.Generic;
using System.Text;
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
using Microsoft.Crm.Sdk.Query;
namespace MonthlyOppDetail
    public class MonthDetailCreationHandler : IPlugin
        #region IPlugin Members
        public void Execute(IPluginExecutionContext context)
            if (context.MessageName == MessageName.Update
                && context.InputParameters.Contains("Target")
                && context.InputParameters["Target"] is DynamicEntity)
                DynamicEntity entity = (DynamicEntity)context.InputParameters["Target"];
                //Check that target entity is opportunity
                if (entity.Name != EntityName.opportunity.ToString())
                    return;
                //Check that this opportunity has entered needed fields
                if (!entity.Properties.Contains("estimatedvalue"))
                    return;
                //values for fields
                decimal sum         = ((CrmMoney)entity.Properties["estimatedvalue"]).Value;
                CrmMoney sum223     = new CrmMoney();
                sum223.Value        = sum / 2;
                ICrmService crmservice = context.CreateCrmService(true);
                DynamicEntity       entityM         = new DynamicEntity();
                TargetCreateDynamic targetCreate    = new TargetCreateDynamic();
                CreateRequest       createRequest   = new CreateRequest();
                entityM.Name = "tcc_oppmonthly";
                CrmMoneyProperty _Tcc_value = new CrmMoneyProperty();
                _Tcc_value.Name                 = "tcc_value";
                _Tcc_value.Value                = sum223;
                entityM.Properties.Add(_Tcc_value);
                KeyProperty _tcc_monthlydetailsid = new KeyProperty();
                _tcc_monthlydetailsid.Name  = "tcc_monthlydetailsid";
                _tcc_monthlydetailsid.Value = (Key)entity.Properties["opportunityid"];
                entityM.Properties.Add(_tcc_monthlydetailsid);
                targetCreate.Entity = entityM;
                createRequest.Target = targetCreate;
                crmservice.Create(entityM);
        #endregion IPlugin Members
Регистрацию провожу на Post событие Update, Parent pipeline . В синхронном режиме - в файл трассировки записано только "The entity with a name = 'none' was not found in the MetadataCache., ErrorCode: -2147217150". В асинхронном - также |Level: Error | MessageProcessor.Execute
>MessageProcessor fail to process message 'Create' for 'tcc_oppmonthly'.
[2009-08-28 19:35:56.0] Process: w3wp |Organization:959e4b7c-ab67-dd11-b616-000c29704829 |Thread: 6 |Category: Platform.Sdk |User: b04a20e9-ab67-dd11-b616-000c29704829 |Level: Error | DefaultExceptionHandler.Handle
>CrmSoapExtension detected non-CrmException - report will be sent to Watson:
System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> System.InvalidCastException: Unable to cast object of type 'Microsoft.Crm.Sdk.KeyProperty' to type 'Microsoft.Crm.Sdk.LookupProperty'.
Пока не могу понять - почему KeyProperty ошибка есть только в одном режиме.
Заранее благодарен за указание ошибок.
Спасибо.
plugin, экземпляр
Как получить значение поля одной сущности при обработке формы другой сущности zhenek Dynamics CRM: Разработка 25 05.07.2011 16:19
Как создать экземпляр кастомной сущности через SOAP? Tony Green Dynamics CRM: Разработка 7 27.02.2009 08:37
Создание и регистрация плагина на Execute и Retreive a33ik Dynamics CRM: Разработка 7 30.11.2008 15:03
Модификая контекста плагина ZooY Dynamics CRM: Разработка 3 28.09.2008 13:52
Создание объекта сущности из другого объекта! SnSS Dynamics CRM: Разработка 5 29.05.2008 13:38
Часовой пояс GMT +3, время: 12:44.
