Старый 28.10.2009, 10:19   #11
DSPIC is offline
DSPIC
Боец
1,077 / 1243 (44) ++++++++
2 sukhanchik: а можно привести исходный код медода queryAddDynaCursorAsRangeAndValue(), а то у меня его нет
// This method will traverse dynalinks on QueryBuildDataSource represented by _queryDynaBdsNo
// and convert current dyna-record into ranges and values on that QueryBuildDataSource
static client server void queryAddDynaCursorAsRangeAndValue(
    Query   _query,             // new query
    Query   _queryDyna,         // query having external links (=dyna links)
    Integer _queryDynaBdsNO     // queryBuildDataSource on _queryDyna having external links
    QueryBuildRange     toQbr;
    QueryBuildDynalink  qbDyna;
    Counter             dynaLinkNo = 1;
    Counter             toI;
    DictField           dictField;
    Integer             dictIndex;
    Integer             originalId;
    Integer             queryDsNO = _queryDynaBdsNO;
    fieldId             id;
    if (!_queryDynaBdsNO)
        return;
    if (!_query || !_queryDyna)
        throw error(strfmt("@SYS23669",funcname()));
    if (!_queryDyna.dataSourceNo(_queryDynaBdsNO))
        throw error(strfmt("@SYS23667",funcname()));
    if (_query.dataSourceCount() < _queryDynaBdsNO || _query.dataSourceNo(_queryDynaBdsNO).file() != _queryDyna.dataSourceNo(_queryDynaBdsNO).file())
        _query.addDataSource(_queryDyna.dataSourceNo(_queryDynaBdsNO).file());
        queryDsNO = _query.dataSourceCount();
    while (dynaLinkNo <= _queryDyna.dataSourceNo(_queryDynaBdsNO).dynalinkCount())
        qbDyna      = _queryDyna.dataSourceNo(_queryDynaBdsNO).dynalink(dynaLinkNo);
        id          = fieldExt2Id(qbDyna.field());
        originalId  = id;
        toQbr       = null;
        if (_query.dataSourceNo(queryDsNO).findRange(id))
            toI = 1;
            while (true)
                toQbr  = _query.dataSourceNo(queryDsNO).findRange(id,toI);
                if (!toQbr || !toQbr.value() || toQbr.value() == queryValue(qbDyna.cursor().(qbDyna.dynamicField())))
                    break;
                toI++;
        if (!toQbr || (toQbr && toQbr.value() && queryValue(qbDyna.cursor().(qbDyna.dynamicField())) && toQbr.value() != queryValue(qbDyna.cursor().(qbDyna.dynamicField()))))
            // is this a Dimension field?
            dictField = new DictField(_query.dataSourceNo(queryDsNO).table(),id);
            if (dictField.arraySize() > 1)
                // yes, working with Array field
                dictIndex = originalId >> 16;
                toQbr  = _query.dataSourceNo(queryDsNO).addRange(fieldId2Ext(id, dictIndex));
            else
                toQbr  = _query.dataSourceNo(queryDsNO).addRange(id);
        if (toQbr)
            toQbr.value(queryValue(qbDyna.cursor().(qbDyna.dynamicField())));
        dynaLinkNo++;
За это сообщение автора поблагодарили: lev (2).
dynalink, полезное
Как настроить DynaLink или фильтр в форме s.alex DAX: Программирование 9 31.08.2009 14:54
axaptapedia: Tutorial Form Dynalink Blog bot DAX Blogs 0 22.08.2007 23:00
Как программно разорвать или восстановить соединение через AxaptaCOMConnector? sschainik DAX: Программирование 3 24.11.2006 08:49
Ошибка (?) в периодических журналах ГК Anais DAX: Функционал 1 10.06.2005 13:20
Создание строк в журналах ГК May DAX: Функционал 2 03.01.2004 23:29
Часовой пояс GMT +3, время: 03:00.
