Старый 10.02.2010, 13:05   #1
25,643 / 848 (80) +++++++
SysDictCoder: Intrinsic function weirdness
Источник: http://sysdictcoder.com/blog/intrins...ion-weirdness/
Over at Dynamics Ax Daily I found a post about a compile error using tableNum() in a select statement.
As mentioned there, the following code doesn’t compile.
select extCodeTable where extCodeTable.ExtCodeTableId == tableNum(CompanyInfo) join extCodeValueTable where extCodeValueTable.ExtCodeId == extCodeTable.ExtCodeId;
The compiler chokes on the call to tableNum(). I was surprised to see this, as I could have sworn that I have used tableNum() in select statements before. As it turns out it does compile in some cases.
It compiles without the join.
select extCodeTable where extCodeTable.ExtCodeTableId == tableNum(CompanyInfo);
It also works if you add another where clause after tableNum().
select extCodeTable where extCodeTable.ExtCodeTableId == tableNum(CompanyInfo) && extCodeTable.RecId != 0 join extCodeValueTable where extCodeValueTable.ExtCodeId == extCodeTable.ExtCodeId;
And using a non-intrinsic function works too.
select extCodeTable where extCodeTable.ExtCodeTableId == str2int("1234") join extCodeValueTable where extCodeValueTable.ExtCodeId == extCodeTable.ExtCodeId;
This example doesn’t make much sense with regards to business logic but it does compile.
I’m guessing this is a bug in the compiler. As far as I can tell it only fails when you use an intrinsic function before a join clause. Until it’s fixed just use a variable or throw in another where clause to check for RecId != 0. Since all records have a RecId it won’t affect the results you get back. This happens in Ax 4.0 and 2009.
All intrinsic functions are listed on MSDN.
Старый 10.02.2010, 18:07   #2
Да, и в 6ке его тоже не захотели фиксить. Так что, ребята, создавайте переменные.
Старый 11.02.2010, 09:13   #3
gl00mie is offline
gl00mie
3,684 / 5798 (201) ++++++++++
Чем мотивируют?
Старый 11.02.2010, 11:44   #4
Чем мотивируют?
There is an easy workaround
CRM Programmer: Upgrade of javascript function to hide "Add Existing ..." button Blog bot Dynamics CRM: Blogs 0 21.12.2009 20:05
CRM DE LA CREME! Some useful CRMform jscripts Blog bot Dynamics CRM: Blogs 0 02.09.2009 10:05
SysDictCoder: Changing properties of AOT objects in code Blog bot DAX Blogs 0 04.05.2009 20:05
daxmy: AOT Find function Blog bot DAX Blogs 0 17.08.2007 01:23
SysDictCoder: Moving the blog Blog bot DAX Blogs 1 05.07.2007 01:56
Часовой пояс GMT +3, время: 09:34.
