Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 09.03.2010, 20:18   #1
Damon is offline
Damon
Building an escape sequence in AX 3.0
Hi,
I have to print a barcode in Axapta 3 and for various reasons i have to use
ann escape sequence to achieve this.
I have written the report display items and methods etc, but my problem is
that the escape sequence has 2 zero (null) values in it.
Axapta (or windows?) filters these out so that they never make it to the
printer.
I have proved this by outputting this escape string to a file and the nulls
are missing.
So my question is how do i get axapta to allow zero values in an escape
string?
The code in the method is below.
The string building is in two stages purely to keep the two escape sequences
visibly separate in the source code.
display str empline1()
  str myString;
  myString = num2char(27)+num2char(16)+num2Char(65)+num2char(8)+num2char(4)+num2char(0)+num2char(0)+num2char(3)+num2char(1)+num2char(1)+num2char(1)+num2char(1);
  myString = myString+num2char(27)+num2char(16)+num2char(66)+num2char(14)+num2char(65)+'1111-1234567'+num2char(103);
  element.setEscapeSequence(myString);
  return element.passThrough(myString);
thanks in advance.
Старый 09.03.2010, 21:30   #2
Сообщение от Damon Посмотреть сообщение
my problem is that the escape sequence has 2 zero (null) values in it.
Use Binary or BinData classes.
Binary example: WinAPI::getComputerName()
BinData exampl: PDFViewer::writeBitmap()
Arijit Basu: New Number Sequence for new AX Module Blog bot DAX Blogs 1 16.04.2007 10:39
Часовой пояс GMT +3, время: 11:18.
