Старый 10.03.2010, 14:53   #7
zkk is offline
zkk
Спасибо за помощь
Вот в итоге нашел решение на Onchange event
Код:
if (crmForm.all.to.DataValue != null && crmForm.all.directioncode.DataValue == true)
var lookUp = new Array();
lookUp = crmForm.all.to.DataValue;
var pId = lookUp[0].id;
var pType = lookUp[0].typename;
var phoneField = "telephone1";
if (pType == "systemuser")
phoneField = "address1_telephone1";
var authenticationHeader = GenerateAuthenticationHeader();
 // Define the SOAP XML to access Microsoft Dynamics CRM Web service.
 var xml = "<?xml version=\"1.0\" encoding=\"utf-8\"?>" +
 "<soap:Envelope xmlns:soap="+
 "\"http://schemas.xmlsoap.org/soap/envelope/\" "+
 "xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" "+
 "xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\">" +
 authenticationHeader+
 "<soap:Body>" +
 "<Retrieve xmlns="+
 "\"http://schemas.microsoft.com/crm/2007/WebServices\">" +
 "<entityName>" + pType + "</entityName>" +
 "<id>" + pId + "</id>" +
 "<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'><q1:Attributes><q1:Attribute>" + phoneField + "</q1:Attribute></q1:Attributes></columnSet>" +
 "</Retrieve>"+
  "</soap:Body>" +
 "</soap:Envelope>";
// Create an instance of an XMLHTTP object.
 var xmlHttpRequest = new ActiveXObject("Msxml2.XMLHTTP");
// Configure the XMLHttp object for the
// Microsoft CRM Web services.
 xmlHttpRequest.Open(
  "POST",
  "/mscrmservices/2007/CrmService.asmx",
  false
 xmlHttpRequest.setRequestHeader(
  "SOAPAction",
  "http://schemas.microsoft.com/crm/2007/WebServices/Retrieve"
  "Content-Type", "text/xml; charset=utf-8"
  "Content-Length", xml.length
// Send the XMLHttp request.
 xmlHttpRequest.send(xml);
// Capture the XMLHttp response in XML format.
 var resultXml = xmlHttpRequest.responseXML;
var pNum = null;
if (resultXml.selectNodes("//q1:" + phoneField).length == 1)
crmForm.all.phonenumber.DataValue = resultXml.selectSingleNode("//q1:" + phoneField).text;
crmdude: Querying a PartyList field Blog bot Dynamics CRM: Blogs 0 14.09.2009 11:05
Как вытащить данные из лукапа на 2 сущности? vital.mih Dynamics CRM: Функционал 1 06.07.2009 16:07
Отображение полей partylist в представлениях OlegaN Dynamics CRM: Разработка 1 26.06.2009 14:14
Поля partylist, поиск и сортировка sergeyjb Dynamics CRM: Функционал 0 25.12.2008 14:00
Шаблон заполнения поля Телефон Talisman2005 Dynamics CRM: Разработка 2 17.06.2008 10:28
Часовой пояс GMT +3, время: 03:22.
