Старый 30.03.2010, 18:26   #1
ist is offline
ist
exist method on temporary table
Hi,
I'm trying to make exist method on temporary table something like this...
Код:
static boolean exist(MyTempTable _tempTable,
                             RefTableId      _tableId,
                             RefRecId        _recId)
    return _tableid && _recId && (select RecId from _tempTable
                                                   where _tempTable.TableNum = _tableId
                                                       && _tempTable.RecordNo = _recId
             ).RecId != 0;
Just like find() methods on a temp table, I pass the temporary table reference as parameter, but compiler throw an error "The table _tempTable does not exist".
Any ideas what's the problem?
Старый 30.03.2010, 18:48   #2
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
                             RefRecId        _recId)
    if(! _tableid || !_recId)
        return false;
    return _tempTable.RecId != 0;
За это сообщение автора поблагодарили: ist (1).
Старый 30.03.2010, 19:08   #3
ist is offline
ist
tks.
Старый 31.03.2010, 10:16   #4
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
Just to make it clear for you. See the "Select statement" article in the Dev Guide:
Field select
It is also possible to use a select statement in a lookup on a field. After a select statement that fetched a record in a table, you can write .field name to reference a field in the table.
Notice the difference between the normal select and the field select. The field select operates directly on a table, whereas the select statement operates on a table variable.
временная таблица
PatrickChua: Temporary table Blog bot DAX Blogs 0 04.05.2009 14:05
method insert() when insert table from outside susenyudha DAX in English 1 29.08.2008 18:51
Axapta Lessons: Export a table to a file Blog bot DAX Blogs 0 28.10.2006 18:22
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 20:23.
