Старый 08.02.2007, 22:31   #1
25,626 / 848 (80) +++++++
Kashperuk Ivan: AxGoToDeclarationI haven't posted in a while. W...
Источник: http://kashperuk.blogspot.com/2007/0...posted-in.html
AxGoToDeclaration
I haven't posted in a while. Work, work...
Well, meanwhile, I made some new handy tool for Axapta developers.
Purpose
Finds the declaration of the selected variable and opens the editor on the line with the declaration
Functional capabilities
Searches the current method first. If the declaration is not found, goes to the root of the object and looks in the classDeclaration method. If still not found, continues on with the parent of the class.
Implementation
In order to use the tool simply import the project
HERE
and post the following code as a new method of the EditorScripts class:
void AOT_goToDeclaration(Editor e)
AxGoToDeclaration goToDeclEngine;
goToDeclEngine = new AxGoToDeclaration(e);
goToDeclEngine.goToDeclaration();
Known Issues:
  • ParserClass does not parse the constructor (new) method. So variable declarations cannot be found from this method.
  • Does not find variables this, element, etc.
  • Does not find objects with AutoDeclaration set to Yes on forms, nor the datasources
What is planned for upgrade:
  1. Open AOT objects when this or element is selected (table, class, form, etc)
  2. Open AOT objects with the property sheet for objects with AutoDeclaration = Yes
  3. Include global classes into the search
Credits Thanks to
  • AndyD - for the timer AOT edit code and the selectedLine method modifications
  • MaxBelugin - for ParserClass description
Feedback
If you have any comments or suggestions, please feel free to contact me.
За это сообщение автора поблагодарили: alex55 (-1).
Старый 06.06.2010, 16:47   #2
alex55 is offline
alex55
224 / 145 (5) +++++
Иван, извини, на самом деле хотел +1 поставить, но что-то не сработало
Старый 07.06.2010, 00:06   #3
это все равно боту пошло, так что "knock yourself out", как говорится.
Kashperuk Ivan: Microsoft Dynamics AX 2009 Keyboard shortcuts Blog bot DAX Blogs 5 18.12.2013 18:24
Kashperuk Ivan: Microsoft Dynamics AX 4.0 data model overview Blog bot DAX: База знаний и проекты 81 16.12.2013 15:25
Kashperuk Ivan: Find all reports with datasources innerjoined 1:n Blog bot DAX Blogs 2 09.03.2008 14:05
Kashperuk Ivan: Buy MorphX IT in Russian Blog bot DAX Blogs 6 13.04.2007 17:48
Kashperuk Ivan: AxCreateNewProject tool Version 1.2I made some a... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 11:17.
